!--error 21
Invalid index.
do_eval: Error while calling block Kalman_Filter_IF [uid='65b73f57:18ea0a60c83:-7fdd']: invalid parameter (ier=21.000000, %scicos_prob=
%F).
I know the error is in the below line of code are as ![]()
**[ok, x0_set, covariance_matrix, exprs] = scicos_getvalue("Set Properties and State", labels, types, exprs);**
x = [];
y = [];
typ = [];
// Kalman filter initial state and covariance
initial_state = [0.0; 0.0]; // 2*1 matrix
initial_covariance = [1.0, 0.0; 0.0, 1.0]; // 2*2 matrix
model.cpar = initial_covariance; // Use covariance matrix as a parameter
dis
select job
case "set" then
x = arg1;
graphics = arg1.graphics;
exprs = graphics.exprs;
model = arg1.model;
while %t do
labels = ['Initial state [x_dot, x]', 'Covariance']; // Changed 'Stiffness' to 'Covariance'
types = list('vec', 2, 'mat', 2); // Changed 'vec' to 'mat' for Covariance
// Check return
if ~ok then
break;
mess = [];
// Check parameters
if ok then
model.state = [x0_set; reshape(covariance_matrix,1,4)]; // Use the concatenation operator ":" for the matrix
graphics.exprs = exprs;
x.graphics = graphics;
x.model = model;
break;
message("Failed to update block io");
// Define block properties
case "define" then
// Create object
model = scicos_model();
// Provide name and type
model.sim = list("Kalman_Filter_sim", 5);
// Define inputs and outputs
model.in = 1; // it's only z
model.in2 = 1; // the second dimension of I/P
model.intyp = 1;
// One output with a single "double" element
model.out = [2; 2];
model.out2 = [1; 2];
model.outtyp = 1;
// Set initial state
model.state = [initial_state; matrix(initial_covariance, 4, 1)]; // Use the matrix concatenation function
// For example: [initial_state; initial_covariance(:)]
// Set default parameter
model.rpar = initial_covariance; // Use the covariance matrix as a parameter
model.blocktype = "c";
model.dep_ut = [%t %f];
// Set block properties
exprs = ["[0.0; 0.0]"; "[1.0]"];
x.graphics.style = ["blockWithLabel;displayedLabel=Kalman_Filter"];
As you can see that until 27 it is printed but after that 28 is not printed so there is issue in this line. Help me to debug it.
