As per mention in the Xcos block setup Block Parameters.
There is requirement of two file for block in XCOS. Simulation file and Interface file. Model setup has error in the interface file and code is
// Kalman_Filter_IF.sci
// The interface file for the generic Kalman Filter block.
// This block is externally activated to take measurements data.
// Takes the continuous positions velocity or accelerations as input, adds some
// errors (noise, scale, nonlinearity, misalignment) and gives
// it as the output.
// Abbrev.
// IF: Inertial Frame, BF: Body Frame,
// Model input:
// 2x2 Real - State vector with position and velocity BF w.r.t. IF
// 1 Real - Covariance vector
// Model output:
// 2x2 Real - Single axis gyro measurement output w.r.t. BF
// 1x1 Real - Error flag
// 0: No error
// 1: Positive saturation error
// 2: Negative saturation error
// Model states:
// 1x1 Real - Random walk error
// Model parameters:
// 2x2 Real - State Vector measurement unit vector w.r.t. BF (Unit vector)
// 1x1 Real - Noise mean (bias) of the sensors
// 1x1 Real - Noise stddev of the sensors
// 1x1 Real - Scale error
// 2x1 Real - Misalignment error
funcprot(0);
x = [];
y = [];
typ = [];
getInputFromSim = 1;
initial_state = [0.1; 0.0]; // 2*1 matrix
initial_covariance = [1.0, 0.0; 0.0, 1.0]; // 2*2 matrix
select job
case "plot" then
standard_draw(arg1);
case "getinputs" then
[x, y, typ] = standard_inputs(arg1);
case "getoutputs" then
[x, y, typ] = standard_outputs(arg1);
case "getorigin" then
[x, y] = standard_origin(arg1);
case 'set' then
// Assignments here comes after assignments of the execution with the "define" flag
x = arg1; // This line is essential, otherwise gives "Invalid index." error.
graphics = arg1.graphics;
exprs = graphics.exprs;
model = arg1.model;
if getInputFromSim == 1 then
exec("macros/Kalman_Filter_Utils.sci",-1); // Not sure about this line in MATLAB, comment it if not necessary
title = "Set Parameter";
labels = ['Initial state [x_dot(velocity), x(position)] which is position in ECEF frame and velocity';
'Covariance which gives the uncertainty at position and velocity'];
// Changed 'Stiffness' to 'Covariance'
// In future we can add {'Accelerations', 'Orientations which is obation altitude control system'}
types = list('vec', [2,1], 'mat', [2,2]); // Changed 'vec' to 'mat' for Covariance
endLoop = %f;
while ~endLoop do
[ok, State, Covariance, exprs] = scicos_getvalue(title, labels, types, exprs);
errMsg = [];
// Check return set conditions of the initial state as per meetings
if ~ok then
// depends on what type of data we are having
if State>0 // first condition of position and velocity
errMsg = ["The velocity is positive [m/s]"];
if condition2 // second condition of velocity
errMsg = [];
if isempty(errMsg) then
[model.rpar, isError] = EncodeRpar_KF(model.rpar, State, Covariance);
graphics.exprs = exprs;
x.graphics = graphics;
x.model = model;
endLoop = %t;
// Check parameters
messagebox(errMsg);
error(errMsg, 20000);
endLoop = %f;
warning('Kalman_Filter_IF: Set: Cancel!');
endLoop = %t;
model.state = [concatAB(initial_state,initial_covariance)];
model.rpar = initial_covariance; // Use the covariance matrix as a parameter
x.model = model;
break
message("Failed to update block io");
// model.state = [State; Covariance(:)]; // Use the concatenation operator ":" for the matrix
// Define block properties
case 'define'
// Create object
model = scicos_model();
// Provide name and type
model.sim = {'Kalman_Filter_sim', 5}; // what is case 4 and 5? https://help.scilab.org/scicos_model.html
// Define inputs and outputs
model.in = [2;2]; // first dimension of the first input whcih is row 2*1 and 2*2 hence it will be [2;2]
model.in2 = [1;2]; // the second dimension of I/P port is [1;2] from above
model.intyp = [1;1]; // all the vector and matrices are real value
model.out = [2;2]; // first dimension of the first output whcih is row 2*1 and 2*2 hence it will be [2;2]
model.out2 = [1;2]; // the second dimension of O/P port is [1;2] from above
model.outtyp = [1;1]; // all the vector and matrices are real value
//model.state = [initial_state,matrix(initial_covariance)]; // Use the matrix concatenation operator ":" to convert matrix to column vector model.state=[State;Covariance]
model.rpar = [initial_covariance(:)]; // Use the covariance matrix as a parameter
model.blocktype = "c";
model.dep_ut = [%t,%f]; // what does %t and %f indicates? true and false
// Set block properties
exprs = ["[0.1; 0.0]";"1.0, 0.0; 0.0, 1.0"]; // How do we get this value?
x.graphics.style = ['blockWithLabel;displayedLabel=Kalman_Filter'];
// other cases other than set or define sections
The error is
>! Building macros…
>! Creation of [spacecraft_gnc_tbxlib] (Macros) –
>! genlib: Processing file: Common_Utils.sci
>! genlib: Processing file: GravityGradient_Utils.sci
>! genlib: Processing file: Gyroscope_SIM.sci
>! genlib: Processing file: Gyroscope_Utils.sci
>! genlib: Processing file: Kalman_Filter_IF.sci
>! genlib: Processing file: Kalman_Filter_IF.sci~
>! genlib: Processing file: Kalman_Filter_Utils.sci
>! genlib: Processing file: MagneticField_Utils.sci
>! genlib: Processing file: Magnetometer_Utils.sci
>! genlib: Processing file: Magnetorquer_Utils.sci
>! genlib: Processing file: ReactionWheel_Utils.sci
>! genlib: Processing file: RigidBody_Utils.sci
>! genlib: Processing file: StarTracker_Utils.sci
>! Building blocks…
>! at line 8 of function scicos_block ( C:\Program Files\scilab-2024.0.0\modules\scicos\macros\scicos_scicos\scicos_block.sci line 29 )
>! at line 29 of function standard_define ( C:\Program Files\scilab-2024.0.0\modules\scicos\macros\scicos_scicos\standard_define.sci line 50 )
>! at line 110 of function Kalman_Filter_IF ( C:\Users\Vims\Desktop\spacecraft-gnc-tbx\macros\Kalman_Filter_IF.sci line 141 )
>! at line 1 of executed string
>! at line 78 of function tbx_build_blocks ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_build_blocks.sci line 90 )
>! at line 7 of function buildmacros ( C:\Users\Vims\Desktop\spacecraft-gnc-tbx\macros\buildmacros.sce line 10 )
>! at line 14 of executed file C:\Users\Vims\Desktop\spacecraft-gnc-tbx\macros\buildmacros.sce
>! at line 13 of function tbx_builder ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_builder.sci line 26 )
>! at line 40 of function tbx_builder_macros ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_builder_macros.sci line 55 )
>! at line 34 of function main_builder ( C:\Users\Vims\Desktop\spacecraft-gnc-tbx\builder.sce line 43 )
>! at line 50 of executed file C:\Users\Vims\Desktop\spacecraft-gnc-tbx\builder.sce
>! scicos_new: Wrong value for input argument #2: unable to set “model”.
Can you please point out that where is the error?
