The tollbox SIMM needs to be updated to work with the newer versions of Xcos and Coselica.
While this may happen, we think our problem can be solved with only Xcos/Coselica.
We need help/training on how to do that.
The goal is to model a DC motor acting on a mechanism.
Input (example): Voltage PWM command, current sensing.
Output: rotation angle on the mechanism. Torque is dependant of position (angle)
If you know anyone who could help
Please let us know
COSELICA is installed correctly. Schematics can be created in XCOS.
However, SIMM creates problems.
It’s pretty annoying, all this talk of incompatible modules. DASSAULT SYSTEM, which took over the lead of SCILAB, should also have taken over the lead of the most widely used modules, namely :
CPGE, COSELICA, SIMM at the very least.
As a result, I’m still using my SCILAB 5.5.2 version, which works perfectly with all these modules. It’s a real shame.
I let @vincent.couvert answer you as he knows the Scilab story from the inside. Noboby decided one day to stop supporting these modules, the situation is more complicated…
Thanks for your feedback about Scilab (and particularly your post about uiimport).
We just updated the SIMM toolbox on ATOMS, this module should now work with Scilab 2024.0.0 (and recent 2024.1.0 version).
As @mottelet said, the situation is quite complicated for many ATOMS modules as the successive maintainers sometimes only posted binary versions on ATOMS (and did not contribute to the source code on Scilab forge for example) hence creating a difference between the available binaries and sources. Once in this situation, updating the toolbox is complicated and time consuming.
Development team is only composed of a few people and maintaining Scilab in already a huge work so we do not have lot of time for ATOMS toolboxes but we do our best. This is why contributions are welcomed from the users community and now Scilab (and most ATOMS toolboxes) source are available on Gitlab, contributing is very much easier.
I’m well aware of the workload involved. I must say that it’s already a great satisfaction to see that SCILAB has been (re)taken in hand by competent and motivated people. The successive changes that have taken place in close succession are testimony to this. For my part, I’m not a developer, just a user, otherwise I’d have loved to be part of this renaissance.
And finally, how can I go about testing the new SIMM on the latest version of SCILAB?
With SCILAB-2024.1.0 + Coselica 2024.0.0-1 + SIMM 0.6.2.2.
The toolbox loading runs fine and smoothly
Thank you
I tried again the model shared some months ago
I used the “5.5.2” model as the “2023” was giving error messages.
The work starts … compiling … linking … but stops with this message. Link done. WARNING: Diagram contains implicit blocks, compiling for implicit Solver. WARNING: Diagram has been compiled for implicit solver WARNING: switching to implicit Solver
“SIMM post”*
“Error in post_xcos_simulate: ending simulation.”*
Any clues ?
What can cause that?
Where should I look?
I am trying the new version of SIMM in SCILAb 2024.1.0
Installation was fine. No encountered problems.
My first try is very simple :
All blocks come from SIMM palette.
We can see a problem regarding REP_TIME block.
Then I lauch the simulation, and I have an error message
When I click on OK button, I have errors messages in the console.
ATTENTION : Le diagramme contient des blocs implicites, compilation en cours pour le solveur implicite.
"SIMM post"
"Erreur dans post_xcos_simulate : Simulation interrompue."
So, it seems I get the same kind of errors than QwillDune.
Remark : As I am french, my SCILAB version is in french. Sorry for french texts in this post.
I just wanted to share a comment about file names regarding old SCILAB versions (for example in 6.1.1 version).
Indeed, files names are very important with COSELICA and SIMM pallettes.
Avoid accentuated characters and spaces in file names.
Otherwise, an error is generated and the simulation stops :
Once the name is correct, it’s possible to simulate a diagram (with a few restrictions). Here’s an example:
I installed the updated versions of Coselica and SIMM and when I run my demo file (cf. above), I get the following error message : -----Message d’erreur du traducteur Modelica:-----
In the console, I get :
Fonction principale Modelica : C:\Users\Pascal\AppData\Local\Temp\SCI_TMP_4280_31713\RLC_s_rie_SIMM_im.mo
“c_pass1: build the modelica meta-block failed”
“xcos_simulate : Erreur à la mise à jour des paramètres de bloc.”
Thank you for your link.
Finally, the installation of vcredist_x86.exe solved the problem. No need to do other things.
The simulation is working fine. Moreover, the block named TIME is working fine too.
So it is possible to mix simulations with TIME and with the clock block.
I have not yet tested PARAM_VAR.
Do you know if CPGE will be restored for working with SCILAB 2025?
And I got also problems to save my file.
I will investigate…
Very strange: when I want to save a file, evrything seems OK, but there is no saved file. And If I take a look on the name of the file, I see name_of_the_file.ssp.
However, I have no problem with sci or sce files.
So I totally uninstalled SCILAB and reinstalled it without any package, but the problem is remaining. I can’t save anymore XCOS files.
Finally, I found the following temporary solution elsewhere in this community:
