Convert a XCOS model from Scilab 5.5.2 to Scilab 2024
A colleague of mine is using a Xcos model that will only run under Scilab 5.5.2.
He and I tried to run it under Scilab 2024 without sucess.
We are really rookie here.
Can you help find what needs to be adjusted?
Moteur à courant continu avec Scilab-Xcos - 20231006 - Scilab 5_5_2.zcos (5.9 KB)
Moteur à courant continu avec Scilab-Xcos - 20231006 - scilab-2023.1.0 (64-bit) - SIMM NON COMPATIBLE.zcos (3.7 KB)
Thank you
F
Currently SIMM is not available in Scilab 2024. If you are interested to contribute, feel free to push PR to scilab / forge / simm · GitLab.
Thanks,
Clément
Unfortunately, that’s is not something we are capable of.
Would the alternative be to rebuilt the model using “Coselica” TB?
BR
François
In fact SIMM installs fine in Scilab 2024.0.0 (by on-the-fly compilation) but you have to install coselica before, as the dependency of SIMM upon coselica does not seem to be set in the metadata of the package.
However, after satisfying this, there is a problem when SIMM loads:
atomsLoad : Une erreur est survenue au cours du chargement de 'SIMM-0.6.2':
	exec: error on line #172: "Variable non définie : cos_utils_lib"
Coselica & SIMM have been updated to be compatible with Scilab 2025.0.0.
Well done
the “5_5_2” model is working fine now
Thank you
