Scilab hangs when trying to customize a superblock in Xcos
Hi!
Today I created a supeblock using the selection to superblock method. The simulation works fine. I wanted to then pass parameters to the superblock. I opened the menu Superblock_mask->Customise… and started typing in the parameters. While typing, the application hanged. All Scilab windows (Scilab, Xcos, diagrams, Palette browser) stopped responding. The only way to close Scilab was to terminate the task in the task manager. After reopening Scilab, Xcos and my diagrams, any attempt to open the Superblock_mask->Customise menu… hangs the application. Again, it has to be closed from the task manager.
I copied my zcos file to another name and did a test - Scilab also hangs.
My system is Windows 11 24H2 (26100.3476) and Scilab 2025.0.0.
Can anyone tell how to deal with this problem?
Regards!
Robert
Can you share your diagram (by private message if you prefer) ?
Discussion continues on gitlab: Scilab crashes when trying to customize a superblock in Xcos (#17405) · Issues · scilab / scilab · GitLab
