Debugging commands like setbpt, dispbpt are not recognized on the command panel. On debug environment, the breakpoints configured don’t stop the running of the script.
The version of Scilab is 2025.1.0, that ist the last one version and I use windows 10 64 bits. Have some problem in this version or have some clue about configuration or library needed?
Hello, and welcome to Scilab’s Discourse,
If you want somebody to answer your next questions, you should say at least “hello”…
Concerning your problem, debug commands are described in Scilab’s documentation: debug - Enters the Scilab debugger mode. You are likely mentioning debug commands which were available until Scilab 5.5.2.
Hello!
Excuse me, english is not my language.
I am grateful about your response. Everywhere i saw, show me the outdated method for debug, even the reference Scilab site showed the outdated commands.
I asked AI Gemini and it gave me the outdated method.
thanks a lot.
That’s why this forum is more valuable than any AI !
Can you give the adress on www.scilab.org (reference Scilab site) where the outdated commands are mentioned ?
