Undefined variable: sysdiag
Hello!
I am executing a code with the sysdiag command but I get this error message constantly: “Undefined variable: sysdiag”. I have tried it in Scilab 2024.0.0 and Scilab 2025.0.0 on Linux Mint and in Scilab 2025.0.0 on Windows 10. For testing it, I am using the example from the online help: sysdiag - Create a block diagonal matrix from provided inputs or block diagonal system connection
Has this command been removed from the latest versions? In that case, What command performs the same function now?
Thanks!!
Welcome to this forum !
sysdiag has been replaced (with the same features) by blockdiag - Creates a block diagonal matrix from provided arrays. Block diagonal system connection. since Scilab 6.1.
Thank you very much for the clear answer mottelet!
SamV
