I am on Scilab 2025.0.0. I have an xcos diagram which uses a bunch of scifunc_block_m (with my user-defined functions). When I run the program I get the following error:
"setdiff: Wrong value for input argument #3: Must be in {1,2,"r","c","*"}."
I don’t use setdiff in my code but I believe it is used internally by some other blocks (such as DEMUX, etc). Is there any other way to tell which part of the diagram causes the issue?
BR
