Debugging your code shouldn’t mean adding disp() and pause statements everywhere or trying to guess what’s going wrong.
With the new debugger in SciNotes, available in the Scilab 2027.0.0, you can step through your scripts and understand what happens during execution, directly in your development environment.
What can you do with the new debugger ?
- Set breakpoints to pause execution exactly where you want.
- Inspect variable values by hovering over variable names during debugging.
- Use conditional breakpoints to pause execution only when specific conditions are met.
- Manage breakpoints easily by enabling, disabling or removing them, including across multiple files.
- Whether you’re tracking down a tricky bug or simply trying to understand how your code behaves, the debugger makes the process more intuitive and efficient.
Ready to give it a try?
Open a script in SciNotes, set a breakpoint and start debugging with F5. Step through your code, inspect your variables and find out what’s really happening.
For more details, check out the help page scinotes_debugger
Give the new debugger a try and share your feedback with the community!
