๐Ÿš€ Clustering made interactive in Scilab
Added in Scilab 2026.1.0, this demo combines the best of both worlds: HTML for a sleek, modern UI โ€” and Scilab for the numerical heavy lifting. Every interaction in the HTML panels triggers computations in Scilabโ€™s engine, with results plotted live.
Three popular clustering algorithms run side by side on a single dataset:
:blue_circle: DBSCAN โ€” density-based, detects noise and arbitrary shapes
:green_circle: Mean Shift โ€” finds clusters without specifying their number
:orange_circle: K-Means โ€” the classic partitioning approach
Adjust the parameters, regenerate the data, and instantly see how each method responds โ€” a hands-on way to build intuition about what each algorithm does, and where it shines.
:backhand_index_pointing_right: Try it out and explore your own data!
i have a problem with kmeans
Operator -: Wrong dimensions for operation [5x2] - [6x2], same dimensions expected.
[idx,centroid] = kmeans(K, m);
m=6 and
K as CSV
K.csv (17.1 KB)
first time error warnin, second time it works, seem some old configuration remained stored in the function.
Hello Pascal,
I reproduce your issue. I have fixed it here
Adeline
Thank you, for your time :slight_smile:
