Scilab 2026.1.0 - Highlights & What's New
Scilab 2026.1.0 - Highlights & What’s New
Hi everyone! We’re excited to share a quick tour of the headline features landing in Scilab 2026.1.0. This release brings transparent broadcasting in arithmetic operators, native Excel and Parquet/Arrow I/O, inline documentation right in the console, and a batch of handy machine-learning and matrix utilities.
Automatic expansion in arithmetic operators
Arithmetic operators now perform automatic expansion with no memory overhead: any singleton dimension is automatically replicated to match the other operand. No more repmat() or Kronecker product (.*.) for the most common cases — your code stays compact, readable, and fast.
x = [1; 2; 3];        // column vector (3×1)
y = [10, 20, 30];     // row vector    (1×3)
M = x + y             // 3×3 result, no repmat() needed
See doc operator_expand for the full picture.
Inline documentation with help()
The new help() function prints a short summary of any documentation page directly in the console — quick reminders of syntax and arguments without leaving your workflow.
help pdist2
Statistics & machine learning
  • pdist() — pairwise distances between observations.
  • pdist2() — pairwise distances between two sets of observations.
  • squareform() — convert between a distance vector and a symmetric distance matrix.
  • summary() — describe table or timeseries variables (properties, basic statistics, …).
  • dbscan() now accepts custom metric distances and parameters.
  • kmeans() and meanshift() now rely on pdist2() with euclidian metric under the hood for better performance.
Classdef
Objects defined with classdef now support static properties and methods, rounding out the oriented object programming introduced in 2026.0.0.
Excel Files
A complete set of native XLSX functions is now available:
  • xlsxRead() — read data from an Excel file into a matrix or cell.
  • xlsxWrite() — write a matrix or cell to an Excel file.
  • xlsxInfo() — inspect a file (sheets, ranges, …).
  • xlsxSheet() — manage sheets (add, remove, rename).
Parquet & Arrow support
Two new functions bring Scilab into modern data-engineering workflows:
  • parquetRead() — read a Parquet or Arrow file as a table.
  • parquetWrite() — write a table to Parquet or Arrow.
Quality-of-life additions
  • format("eng") — exponential notation with exponents constrained to multiples of three.
  • ishermitian() / issymmetric() — quick matrix property checks.
  • gallery() gains the "minij" and "moler" symmetric positive definite test matrices.
  • csvTextScan() now supports the "substitute" option, just like csvRead().
Modernization of ATOMS & Demonstrations GUIs
Based on uicontrol browser introduced in Scilab 2025.1.0
Get involved
  • Try the new features and share your feedback, code snippets, and edge cases.
  • Report issues and suggest enhancements on GitLab.
Thanks to all contributors and testers who helped shape Scilab 2026.1.0!
I’ ve installed Scilab 2026.1.0 on my desktop and i got
could also bee, that our sysrtem blocks some dll
M.f.G. Pascal
Hello Pascal,
Strange that are Debug version of Windows Kit libraries.
Let me check what append.
Antoine
Same situation for me with Windows 11.
We found the trouble, we packaged with good version of libraries.
You can download it again.
Sorry for the inconvenience.
Antoine
Yes, now it works on my desktop
thanks
M.f.G. Pascal
It works.
Thank you !
I just had the opportunity to experiment that the features automatic expansion of arithmetic operators and summary(), are really great, thank you all Scilab developers !
Congratulations to the team for this new release.
Yoor hard work is really appreciated.
I did my install and it worked well.
Adding the toolboxes thru the new package manager is great.
While installing SCICV toolbox, i got the following message:
atomsLoad: An error occurred while loading ‘scicv-4.8.1-1’:
exec: error on line #8: “loadToolboxInlineHelp: Wrong number of input argument(s): 2 expected.”
Should I wait for a toolbox update or is there something I can do locally ?
BR
F
Hi @QwillDune
sciCV package is now available for Scilab 2026.1.0.
Best regards,
Vincent
I was using the object features with newly introduced Static optional modifier and I noticed that the help page was missing a detail about syntax, an example how to use it in practice (whenever quite trivial), for instance :
properties (Static, Protected)
    myvar=[]
or
methods (Static, Public)
   function myfunc=()
Also I feel that a bit more complex examples could be elaborated to figure out the mecanisms behind inheritance: for instance in the example below, not sure what is required to get the expected behaviour, like if the call to A() constructor in B() constructor is conceptually or not required. Or why the call to A.aff() within classB_function_aff() is rejected at execution (commented below) ?
Is there a syntax to force the name resolution to clarify the call to a specific function like A::aff() ?
I don’t understand why uncommenting the //(Static, Public) modifier for methods in the A or B class is making fail the execution ? (it seems caused by the Static modifier there )
Thank you for your comments,
classdef A
    properties(Static, Protected)
        a=2
    methods  //(Static, Public)
        function A()
        function aff()
            disp(sprintf("a=%d", this.a))
classdef B<A
    properties
        b=[]
        function B(value)
//            A()
            this.b=value
        function aff()
//            A.aff()
            disp(sprintf("b=%d", this.b))
            disp(sprintf("a=%d b=%d", this.a, this.b))
            disp(sprintf("a=%d b=%d", A.a, this.b))
obj= A();
obj.aff()
objet= B(4);
objet.aff()
