Hi everyone! We’re excited to share a quick tour of the headline features landing in Scilab 2026.0.0. This release brings object-oriented programming to the language, new machine-learning utilities, better model exchange in Xcos, and long-requested plotting improvements.
Objects
Scilab now supports first-class objects:
classdef … endfor class declarations. -
Constructors, properties, methods, enumeration and operator overloading.
Multiple inheritance and well-defined scope/visibility.
Full design notes, guidance, and examples are in the dedicated post: Objects in Scilab
New classification functions
Two widely used clustering algorithms are now built-in:
dbscan(): Density-based clustering that discovers arbitrarily shaped clusters and marks outliers:
rand("seed", 0)
theta1 = 2 * %pi * rand(100, 1);
theta2 = 2 * %pi * rand(120, 1);
theta3 = 2 * %pi * rand(150, 1);
r1 = 1 + 0.2 * rand(100, 1);
r2 = 2.5 + 0.2 * rand(200, 1);
r3 = 4 + 0.2 * rand(300, 1);
X1 = [r1 .* cos(theta1), r1 .* sin(theta1)];
X2 = [r2 .* cos(theta2), r2 .* sin(theta2)];
X3 = [r3 .* cos(theta3), r3 .* sin(theta3)];
N = 10 * (rand(30, 2) - 0.5); //noise
X = [X1; X2; X3; N];
labels = dbscan(X, 0.72);
f = scf();
f.figure_name = "DBSCAN";
f.figure_size = [975 630];
subplot(122)
gca().isoview = "on";
scatter(X(:,1), X(:,2), [], labels, "fill")
title("Circular cluster with noise");
subplot(121)
scatter(X(:,1), X(:,2), [], color(0,127,255), "fill");
title("Raw data");
meanshift(): Mode-seeking clustering requiring minimal prior on the number of clusters:
rand("seed", 0);
n = 200;
x1 = rand(n, 2, "normal") + 2 * ones(n, 2);
x2 = rand(n, 2, "normal") - 2 * ones(n, 2);
x3 = rand(n, 2, "normal") * 1.5 + ones(n, 2);
x4 = rand(n, 2, "normal") * -1.5 - ones(n, 2);
x = [x1; x2; x3; x4];
[c, index] = meanshift(x, 2.2);
f = scf(1);
f.figure_name = "MEANSHIFT";
subplot(122)
scatter(x(:,1), x(:,2), [], index, "fill");
scatter(c(:,1), c(:,2), 150, color(228, 26, 28), "fill"); // centroid of each cluster
title(string(length(unique(index))) + " clusters and centroid");
subplot(121)
scatter(x(:,1), x(:,2), [], color(0,127,255), "fill");
title("Raw data");
Both functions return cluster labels you can pass straight into your plotting pipeline.
Xcos: SSP format support
Xcos now uses SSP format (System Structure & Parameterization) as default format for smoother model exchange with other tools and workflows:
Import an existing system description as an Xcos diagram with parameters.
Export your diagram and parameters as an SSP package for sharing with other tools.
This helps integrate Scilab/Xcos in FMI/SSP-centric environments and toolchains.
Colormaps per axes
You asked, we listened: each axes can now have its own colormap — perfect for side-by-side plots with different palettes.
f = scf();
f.figure_name = "Figure & Axes colormaps";
f.color_map = jet(32);
ax1 = subplot(1, 2, 1);
ax1.title.text = "plot3d() using figure colormap"
x = %pi * [-1:0.05:1]';
z = sin(x)*cos(x)';
e = plot3d(x, x, z, 70, 70);
e.color_flag = 1;
ax2 = subplot(1, 2, 2);
ax2.title.text = "surf() using axes colormap"
ax2.color_map = cool(50);
theta = 0:15:360;
r = 25:5:100;
[R,T] = ndgrid(r,theta);
X = R.*cosd(T);
Y = R.* sind(T);
Z = sinc(R/8);
surf(X, Y, Z)
ax2.rotation_angles=[195 -155];
This removes the old “global colormap” limitation when composing multi-axes figures.
Get involved
Try the new features and share your feedback, code snippets, and edge cases.
Report issues and suggest enhancements on GitLab.
Thanks to all contributors and testers who helped shape Scilab 2026.0.0!
