Things that can be simplified
Hi Scilab team i also noticed that for legends and legend, defining the position is handled differently. Having there also a common handle would be nice. :slight_smile:
M.f.g. Pascal
I also noticed, that sometimes “r” and “c” is used and sometimes 1 or 2. Here a common definition would also be useful.
M.f.G. Pascal
Marker in line spec and scatter i would sa in any plot should be the same.
I would suggest, that Scilab has one general properties for every graphics and the special ones only in defined in the graphic or plot itself?
Hi Scilab Team,
i have also seen in 2027.0.0, that in the Help browser there is the chart pie, would it be better to be into 2d plot?
and multiscale plots into axes operations?
and xchange into figure operations?
and there is also the Bernstein matrix which should be in Matrix generation?
and the xcov should be in Convolution-correlation?
Does any one need read_csv, readxls and write_csv anymore?
