sciLAB fuzzy logic toolbox
I would like to get the fan1.zcos fuzzy logic demo module. Could anyone provide it to me?
Thank you
I am not sure what you mean. The demo comes with the toolbox, right? The toolbox is here:
The toolbox is open source, available on Github, and the demos are here:
Is this what you were looking for?
With kind regards,
Claus
Hello Claus,
Thank you for your reply.
I had already downloaded those demo files.
The one I am specifically reviewing is the fan1 demo. The demo files only have the fan.fls file from which I am able to build up a fan.xcos module using constant input blocks and a mux to combine them so there is only one input to the fls block in xcos. I am trying to read the output using the AFFICH.m module which apparently needs a CLOCK.m input as well, which I am dubious about.
I don’t get consistent results, and I get the same result however I change my input.
Is there a better way to view the output?
Thank you for your assistance.
Regards,
Michael.
Hello Claus,
The one I am specifically reviewing is the fan1 demo. The demo files only have the fan1.fls file (there’s no fan1.xcos file) from which I am able to build up a fan1.xcos module using constant input blocks and a mux to combine them so there is only one input to the fls block in xcos. I am trying to read the output using the AFFICH.m module which apparently needs a CLOCK.m input as well, which I am dubious about.
I get the same result however I change my input values of temperature and humidity..
I am able to execute the flt_fan1test.sce demo module in Xcos which produces the surface speed result for a complete range of temperatures and humidities.
Trying to execute the flt_fan1test.sce demo for just one temperature input and one humidity input, in the scilab console, gives an error message.
Regards,
Michael.
Hello Claus,
If I input the temperature and humidity constants as vectors of shape [1,1], I think I am getting my xcos module to work!
I need to input the values to the fan1.fls module as a vector of shape [2,1].
Regards,
Michael
Michael Smith <mjcsmith1@gmail.com>###
8:54 PM (0 minutes ago)
to Scilab
Hello Claus,
If I input the temperature and humidity constants as vectors of shape [1], I think I am getting my xcos module to work!
Regards,
Michael
