Dear all,
is it possible to import the content of a google spreadsheet (stored at google drive) to scilab?
I was hoping that getURL() would download the content, even if it would be in a messy way, but it did not.
Thank you,
Dear all,
Thank you,
See
For example, the following sheet :
https://docs.google.com/spreadsheets/d/1W3W7VfpKR4_aFWWB8vYJ_lNyb1Nf1hDx4-ZYpNmgEZE/
can be downloaded in csv format by (the follow=%t is mandatory)
http_get("https://docs.google.com/spreadsheets/d/1W3W7VfpKR4_aFWWB8vYJ_lNyb1Nf1hDx4-ZYpNmgEZE/export?gid=0&format=csv",follow=%t)
Hello Stéphane,
thank you.
I think there is something going on with my spreadsheet.
Accessing your example is working fine, even with get URL.
[myFile, content] = getURL(....)
However it does not work with my spreadsheet.
I tried to change access rights, but no success.
I always get something like this:
<!DOCTYPE html><html lang="de"><head><meta name="description" .....
Best regards,
The url you are using in getURL or http_get should also work when you paste it in the address field of your navigator. What message do you get instead ?
→ opens the spreadsheet in the browser
https://docs.google.com/spreadsheets/d/SPREAD_SHEED_ID/export?gid=0&format=csv
→ works with the spread sheet you provided
→ does not work with my spread sheet
The error message is something like this:
I kind of hesitate to publish the link to the spreadsheet here, but if you like I can send it to you via private E-Mail.
Thank you,
Yes, send it to so that I can make some tests.
With the shorter URL (without the gid parameter)
http_get("https://docs.google.com/spreadsheets/d/SPREAD_SHEET_ID/export?format=csv",follow=%t)
it works for me with the SPREAD_SHEET_ID you sent me.
Stèphane,
this is working.
Many thanks.
