pascal
August 14, 2023, 5:51am
1
Hi, i wanted do load the swissmap JSON file from GADM into Scilab 2023.1. Level 0 works with 34kb. But Level 1 with unzipped 134kb crashes Scilab on windows 11. Could anyone confirm this, before making a Bug.
M.f.G. Pascal
[res, status] = http_get(“https://geodata.ucdavis.edu/gadm/gadm4.1/json/gadm41_CHE_1.json.zip","C:\Users\buehlpas\Documents\Scilab\gadm41_CHE_1.json.zip ”);
[output,bOK]=dos(“cd C:\Users\buehlpas\Documents\Scilab\ && tar -xf gadm41_CHE_1.json.zip”);
result = fromJSON(“C:\Users\buehlpas\Documents\Scilab\gadm41_CHE_1.json”, “file”);
//[result, status] = http_get(“https://geodata.ucdavis.edu/gadm/gadm4.1/json/gadm41_CHE_0.json ”, format=“JSON”);
//scale=3;
//coord_x=result.features.geometry.coordinates(1)(1)(:,1);
//coord_y=result.features.geometry.coordinates(1)(1)(:,2);
Hi Pascal
I can make these commands run fine, if I change to single-quotes (changing path to my user space):
→ [res, status] = http_get(‘https://geodata.ucdavis.edu/gadm/gadm4.1/json/gadm41_CHE_0.json.zip’,'D:\Userdata\Claus\Documents\Scilab\gadm41_CHE_1.json.zip ’);
→ [output,bOK]=dos(‘cd D:\Userdata\Claus\Documents\Scilab && tar -xf gadm41_CHE_1.json.zip’);
result = fromJSON(‘D:\Userdata\Claus\Documents\Scilab\gadm41_CHE_0.json’, ‘file’);
Note how CHE_1 changes name to CHE_0 (not sure why, looks confusing, but that’s what is inside the ZIP file).
pascal
August 17, 2023, 5:37am
3
Cannot upload ZIP or JSON data? Have to do it this way
gadm41_CHE_1.json.zip.sod (40.0 KB)
but just remove sod, unzip the file and you have the JSON File from GADM
Thanks
pascal
October 25, 2023, 11:44am
4
Tried with Scilab 2024.0 following code:
countries=["CHE"];
depth=["0","1","2","3"];
URL=["https://geodata.ucdavis.edu/gadm/gadm4.1/json/gadm41"];
path=fullfile(TMPDIR,"Messungen");
ending=[".csv",".svg",".json",".zip"];
[CHF_0, status]=http_get(URL(1)+"_"+countries(1)+"_"+depth(1)+ending(3), format="JSON");
[res, status]=http_get(URL(1)+"_"+countries(1)+"_"+depth(2)+ending(3)+ending(4),path(1)+"GADM");
files=decompress(res,path(1));
CHF_1=fromJSON(files, "file");
works, but fromJSON crashes?
You are right, there is a crash (tested on Scilab 2024.0.0 macOS version). Can you take the time to create a Gitlab account and create an issue at Issues · scilab / scilab · GitLab ? Please include your code above as modified (I have changed the path of the file so that anybody can copy/paste it).
