I have a requirement where the output from a user-defined block needs to serve as the limit for a Saturation block. Is there a way to accomplish this without accessing the programming environment?
For an an upper bound saturation just use the Min_f block: MIN_f - Minimum value of a vector's elements after a mux block (step time is 10s):
vsat.zcos (3.2 KB)
