I have noticed blocks which have en ending of either _f, _c . When does for example the CONST block in sources have three different versions with these annotations?
Thanks.
Thanks.
All these blocks are different implementations of the same mathematical function. Historically, the _f and _c suffixes were the Xcos/Scicos API used in the associated simulation function but this is no more true.
The point is: the implementation differs! Some might support scalar inputs, others matrices; some might have a vector-like operation, others matrix-like; some might saturate on a upper-value set in the parameters, others might overflow as in C; etc…
I read somewhere that the _f was implementation in Fortran and _c was written C. I must have overlocked that there was some difference in the between them besides them. I will look into that ![]()
Thanks !
Hello @davidcl, could you guide me on when to choose “PRODUCT” over “PROD_f” for performing multiplication? I encountered issues with the PRODUCT Block when attempting to use it for division, resulting in the following error message:
Simulation problem:
at block #18" -3b9d4a6a:18e56739c2f.-7de1"
singularity in a block
Xcos error: Partial information in "pout(2)" is unset
for Block '15- "-776dad33:18e55af1a51:-7ee9": a value
between 1 and 39 expected.
However, I managed to get satisfactory outcomes by employing the “INVBLK” Block and the “Prod_f” Block instead.
Hello @Smart, the PRODUCT block is supposed to be better than PROD_f ; it as more parameters to tweak its inputs and the error on divide. Could you post a schema describing the issue ?
Thanks
