Hello. I need to program a userdefined function. The function should be named “MaxRunningResettable.” It should output the maximum of all previously entered values. Additionally, it should be reset by another input signal (PULSE_SC).
This is my code:
function y = MaxRunningResettable(input, hold)
persistent maxVal;
if isempty(maxVal)
maxVal = input;
maxVal = max(maxVal, input);
if hold ~=0
maxVal = 0;
y = maxVal;
now i use the scifunc_block_m with this settings:
but if I try out the block with a sine wave at the first input port an erro occurs. I cant identify the problem. I hope someone can help me.
thanks.
