Questions to animaGIF
Hi there,
animaGIF provides a handy solution to create animations from a set of figures or images.
However I experience some issues using: idGif = animaGIF( gcf(), myPath);
  • Scilab 2025.1.0
  • animaGIF 1.0
  • Windows 11
1.: resulting gif holds only the last frame
2.: image quality is very low
Best Regard,
Here an example of a gif:
It should hold 10 frames, but it just contains only the last.
Image info: 1384 x 1072 x 4 BPP
Some updates:
On a different PC is a slightly different configuration:
  • Scilab 6.1.1
  • Scilab 2025.0.0
  • Win 11
As for Sciab 6.1.1
After fiddeling a little around I had animaGIF working as expected using temporary images as input.
As for Sciab 2025.0.0
Previous to animaGIF the toolbox scicv version 4.8.1-1 was installed.
Installing animaGIF via atoms tried to unload scicv…without success.
Restarting Scilab seem to load scicv and animaGIF … (no other external toolboxes are installed)
Executing the same script did build the GIF, but with lower quality.
Does animaGIF need an rebuild for newer Scilab versions?
Thanks,
You should ask the author.
