Problems using part() function in Scilab 2026.0.1
Dear Scilab community,
I am a newcomer to Scilab, as I am working with a colleague who has given me a .sce file. I have installed Scilab 2026.0.1 via Flatpak under Fedora Linux 43.
My problem concerns the $ syntax in the part() function in that script. I have consulted the official documentation and that example is working:
--> part(['a string' 'another longer one'], $-2:$ )
ans = [1x2 string]
"ing"  "one"
When I am running my script, the line 123 txt=part(txt, 1:$-1); fails (the variable txt was just read from a multilines textfile by txt=mgetl(file_name);):
--> exec('/blabla/myscript.sce', -1)
   0.3815789
in builtin                part
at line   123 of executed file /blabla/myscript.sce
Function not defined for given argument type(s),
  check arguments or define function %ip_part for overloading.
But still stranger, after that, the official example now also fails:
in builtin                part
That problem does not occur if I install Scilab 2025.1.0 using the scilab-2025.1.0.bin.x86_64-linux-gnu.tar.xz archive (but in that version I have big trouble trying to install the ATOMS IPCV, but that it is another story…).
Am I missing something? Or is it a bug?
This is a minimalist snippet showing my problem in 2026.0.1:
clear
Mat=zeros(6, 400)
file_name="~/output.txt"
fprintfMat(file_name, Mat)
txt=mgetl(file_name)    // reading that output file
txt=part(txt, 1:$-1)    // delete the last character of each line
Interactive console (GUI):
 ans = [1x2 string]
  "ing"  "one"
--> exec('blabla/bug.sce', -1)
in builtin                part
at line    10 of executed file blabla/bug.sce
in builtin                part
We did not manage to reproduce this issue.
Can you try with a Scilab official binary version from Scilab 2026.0.1 | Scilab ?
Thanks a lot @vincent.couvert !
I really thought Flatpak would be an easy way to install Scilab in Fedora. But I had that problem on two machines… And big troubles trying to install the ATOMS IPCV.
Now, I have just downloaded the official scilab-2026.0.1.bin.x86_64-linux-gnu.tar.xz and everything works perfectly.
I can now begin my journey learning and using Scilab. Thanks again Vincent.
