The often used toolbox apifun which checks input arguments in macros. It installs in 2027.0.0 but after restarting Scilab I got the error:
atomsLoad: An error occurred while loading ‘apifun-0.4.3’:
add_help_chapter: error on line #71: “add_help_chapter: invalid value for input argument #2: an existing directory is expected.”
(translated from German)
The problem is the old SCIHOME\atoms\x64\apifun\0.4.3\etc\apifun.start which checks for jar/ instead for help/.
To workaround this issue just replace lines 29-32 of SCIHOME\atoms\x64\apifun\0.4.3\etc\apifun.start:
path_addchapter = pathconvert(root_tlbx+"/jar");
if ( isdir(path_addchapter) <> [] ) then
add_help_chapter(modulename, path_addchapter, %F);
with
path_addchapter = pathconvert(root_tlbx+"/help");
if isdir(path_addchapter) then
add_help_chapter(modulename, root_tlbx, %F);
Restart Scilab. Worked for me & will solve problems with other toolboxes using apifun.
Maybe one of the maintainer
- Stéphane MOTTELET
- Michael BAUDIN
- Samuel GOUGEON
- Clément DAVID
of apifun could do the fix and update this useful toolbox? I opened an issue @Gitlab.
