Objects in Scilab: classes, instantiation, and multiple inheritance
Why it matters
Until now, object-oriented patterns were often simulated with mlist/tlist and conventions. Objects make these use cases clearer, more robust, and easier to maintain, and they help structure codebases.
What ships in Scilab 2026.0
Classes with properties, methods and enumeration.
Constructors for instance initialization
Member visibility (public / protected / private)
Multiple inheritance (well-defined and documented method resolution)
Existing mechanisms (
mlist/tlist, overloads) remain available. This is an addition to the language, not a breaking replacement.
Quick start
Declare a class and use it
This example introduces a minimal Point class.
classdef Point
properties
x = 0;
y = 0;
methods
function Point(x, y)
this.x = x;
this.y = y;
function r = norm()
r = sqrt(this.x^2 + this.y^2);
p = Point(3, 4);
p.norm() // 5
norm(p) // 5
The properties block defines fields with default values, and the methods block holds both the constructor (a method named exactly like the class) and regular methods. Inside methods, this refers to the current instance and is implicitly available, you don’t pass it in the signature. The norm method computes the Euclidean length of the point. You can call it in two equivalent ways: instance style (p.norm()) or functional style (norm(p)). Scilab dispatches norm(p) to Point.norm when the first argument is a Point, so both lines return 5 for the (3,4) example.
Simple encapsulation
This example demonstrates encapsulation with a private field.
classdef Counter
properties (private)
n = 0;
methods
function inc()
this.n = this.n + 1;
function v = value()
v = this.n;
c = Counter();
c.n = 10 // Wrong insertion: property 'n' is not accessible.
c.inc(); // +1
inc(c); // +1
c.value() // 2
The counter’s state n is declared private, so only code inside Counter can read or modify it, accessing c.n directly (or doing c.n = 10) is not allowed. All state changes go through methods: inc() increments the counter, and value() returns it.
This example shows multiple inheritance with a lightweight mixin.
classdef ColorMixin
properties
color = "red";
classdef ColoredPoint < Point & ColorMixin
methods
function ColoredPoint(x, y)
Point(x, y);
function s = string()
s = msprintf("(%d, %d) [%s]", this.x, this.y, this.color);
function disp()
disp(string(this));
cp = ColoredPoint(1,2);
cp // (1, 2) [red]
ColorMixin contributes the color property, while ColoredPoint < Point & ColorMixin combines the geometric behavior of Point with the mixin’s attribute. The ColoredPoint constructor delegates to Point(x, y) to initialize coordinates. Member lookup gives you x/y from Point and color from ColorMixin. The string() method defines a textual representation, and the disp() override forwards to string(this), so printing the instance (or just evaluating cp) renders "(1, 2) [red]". If multiple bases declare the same member, Scilab’s method-resolution order decides which one wins; there’s no conflict in this example.
Overloads
This example demonstrates operator overloading.
classdef Point2
properties
x
y
methods
function Point2(x, y)
this.x = x;
this.y = y;
// Overload operation double + Point2 or Point2 + double
function r = plus_s(a, b)
if isa(a, "Point2") then
r = Point2(a.x + b, a.y + b);
r = Point2(a + b.x, a + b.y);
// Overload operation Point2 + Point2
function r = plus_Point2(a, b)
r = Point2(a.x + b.x, a.y + b.y);
// Overload for all other + operation with Point2
function r = plus(a, b)
error("operation not managed.");
s = sprintf("(%d %d)", this.x, this.y);
function disp()
disp(string(this));
p1 = Point2(3, 4) //(3 4)
p2 = Point2(-3, 4) //(-3 4)
p1 + p2 //(0, 8)
p1 + 4 //(7 8)
3 + p2 //(0 7)
p1 + "f" //error
Overloads are resolved by method name: plus_Point2(a,b) handles Point2 + Point2, plus_s(a,b) covers the mixed scalar case (either Point2 + double or double + Point2), and the bare plus(a,b) acts as a catch-all fallback. In plus_s, the isa(a,"Point2") check lets one implementation support both operand orders. Each overload returns a new Point2 with component-wise addition. If no suitable overload exists (e.g., p1 + "f"), the generic plus raises an error.
Documentation
For more details, you can read documentation about Objects in Scilab.
Scilab Team
