!Undefined operation for the given operands. !
!check or define function %c_c_s for overloading. ! I am getting this error but I didnot mention function as mention in the error. So where should I look now?
This is something called “overloading”. You can get more information with help overloading. This function lets you implement a specific operation on Scilab types; however, this usually means you used an operation that is not implemented on purpose.
Could you post the code and the stack trace?
Kalman_Filter_IF.sci (3.3 KB)
Kalman_Filter_SIM.sci (3.1 KB)
Kalman_Filter_Utils.sci (623 Bytes)
This error appear when I am double clicking on block seen in the Xcos. I thing the error is in SIM file which is simulation.
Could you try on Scilab 2024 ? You will get a real Scilab stacktrace instead of the lastmessage.
Hello sir
I solve this issue of overloading. The answer is list(‘vec’,‘1’,‘vec’,‘2’) my mistake was =[‘vec’,‘1’,‘vec’,‘2’].
Thank you
The error message is very explicit : Problem with tag imagedata. The given fileref is not an existing imagefile. . You should fix the XML file to have a valid path to an image file.
do not use screenshot when you can copy paste text. This will ease search
Thanks
yes.
Building the master document:
C:\Users\Vims\Desktop\spacecraft-gnc-tbx\help\en_US
Building the manual file [javaHelp] in C:\Users\Vims\Desktop\spacecraft-gnc-tbx\help\en_US.
at line 693 of function xmltoformat ( C:\Program Files\scilab-2024.0.0\modules\helptools\macros\xmltoformat.sci line 710 )
at line 17 of function xmltojar ( C:\Program Files\scilab-2024.0.0\modules\helptools\macros\xmltojar.sci line 29 )
at line 51 of function tbx_build_help ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_build_help.sci line 67 )
at line 4 of executed file C:\Users\Vims\Desktop\spacecraft-gnc-tbx\help\en_US\build_help.sce
at line 13 of function tbx_builder ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_builder.sci line 26 )
at line 49 of function tbx_builder_help_lang ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_builder_help_lang.sci line 64 )
at line 4 of executed file C:\Users\Vims\Desktop\spacecraft-gnc-tbx\help\builder_help.sce
at line 71 of function tbx_builder_help ( C:\Program Files\scilab-2024.0.0\modules\modules_manager\macros\tbx_builder_help.sci line 87 )
at line 36 of function main_builder ( C:\Users\Vims\Desktop\spacecraft-gnc-tbx\builder.sce line 46 )
at line 54 of executed file C:\Users\Vims\Desktop\spacecraft-gnc-tbx\builder.sce
If Scilab is started in a chroot, you might want to try to set the two environment variables: SCI_DISABLE_TK=1 SCI_JAVA_ENABLE_HEADLESS=1
I got above response and Do you have time sir to seat for 5 min to look into it? I didnot have that much experiences.
I think you should fix it by yourself, this is a domain-specific closed-source toolbox I am not aware of.
Read the error message, the file RigidBody_IF.gif does not exist. It might be generated by the builder.sce file.
Than lets learn ,
1- How did you find out that Rigidbody.gif is missing? Can you please mention the way you understand or debigging it.
I think I found out the solution after 2 days but now there is
--> exec /Users/vimalchawda/Desktop/spacecraft-gnc-tbx/builder.sce
--> // Copyright (C) 2008 - INRIA
--> // Copyright (C) 2009-2011 - DIGITEO
--> // Copyright (C) 2023 - DLR, German Aerospace Center
--> // This file is released under the 3-clause BSD license. See license.txt.
--> mode(-1);Building macros...
-- Creation of [spacecraft_gnc_tbxlib] (Macros) --
genlib: Processing file: Kalman_Filter_Utils.sci
Building blocks...
Building help...
/Users/vimalchawda/Desktop/spacecraft-gnc-tbx/help/en_US
operation +: Warning adding a matrix with the empty matrix will give an empty matrix result.
Building the manual file [javaHelp] in /Users/vimalchawda/Desktop/spacecraft-gnc-tbx/help/en_US.
at line 48 of function tbx_build_help_loader ( /Applications/scilab-2024.0.0.app/Contents/share/scilab/modules/modules_manager/macros/tbx_build_help_loader.sci line 63 )
at line 5 of executed file /Users/vimalchawda/Desktop/spacecraft-gnc-tbx/help/en_US/build_help.sce
at line 13 of function tbx_builder ( /Applications/scilab-2024.0.0.app/Contents/share/scilab/modules/modules_manager/macros/tbx_builder.sci line 26 )
at line 49 of function tbx_builder_help_lang ( /Applications/scilab-2024.0.0.app/Contents/share/scilab/modules/modules_manager/macros/tbx_builder_help_lang.sci line 64 )
at line 4 of executed file /Users/vimalchawda/Desktop/spacecraft-gnc-tbx/help/builder_help.sce
at line 71 of function tbx_builder_help ( /Applications/scilab-2024.0.0.app/Contents/share/scilab/modules/modules_manager/macros/tbx_builder_help.sci line 87 )
at line 35 of function main_builder ( /Users/vimalchawda/Desktop/spacecraft-gnc-tbx/builder.sce line 45 )
at line 51 of executed file /Users/vimalchawda/Desktop/spacecraft-gnc-tbx/builder.sce
Undefined variable: toolbox_title
What does this error mean? Please explain me like previously as kid. Thank you sir.
