I cleared some temp files and as much as I could find from earlier installations. I’m still getting an error just loading the coselica toolbox.
atomsLoad: An error occurred while loading 'coselica-2024.0.0':
add_demo: error on line #28:
"add_demo: The file C:\PROGRA~1\SCILAB~1.0\contrib\coselica\20240~1.0\demos
\coselica.dem.gateway.sce does not exist."
I suspect the next step is someone will want to sell me something. It may be time to look at other options.
Start COSELICA module
Load macros
Load palette: Coselica - Blocks
Load palette: Coselica - Electrical
Load palette: Coselica - Heat transfer
Load palette: Coselica - Mechanics/Translational
Load palette: Coselica - Mechanics/Rotational
Load palette: Coselica - Mechanics/Planar
Load palette: Coselica - Components
Load help
Load demos
add_demo: error on line #28: "add_demo: The file C:\Users\PLATTE~1\AppData\Roaming\Scilab\SCILAB~1.0\atoms\x64\coselica\20240~1.0\demos\coselica.dem.gateway.sce does not exist."
The truth is that file is not there. The entire demos folder was missing. I copied the demos folder from the program files load into this file location and the file it is looking for is NOT in the demos folder. “coselica.dem.gateway.sce” really does not exist.
The package tree is not correct as all the demos files have been created in the toolbox top level folder. It will be fixed soon by the authors but in the meantime you can create a demos folder and copy there all *.dem.sce and the coselica.dem.gateway.sce file.
