disp("Error: arg1 is not of expected type 'Block', 'tlist', or 'hlists'.");
Error: Heterogeneous string detected, starting with " and ending with '.
genlib: Error in file C:\Users\Vimal\Desktop\spacecraft-gnc-tbx-devel-kalman-filter-block\macros\System_IF.sci.
I have found 3 solutions but its not working .
Correct Quotation Marks in disp Statements
Properly matching quotation marks is crucial. Here’s how to handle different scenarios:
- Option 1: Use single quotes for the outer string and double quotes inside.
scilab
Copy code
disp('Error: arg1 is not of expected type "Block", "tlist", or "hlists".');
- Option 2: Use double quotes for the outer string and escape inner double quotes.
scilab
Copy code
disp("Error: arg1 is not of expected type \"Block\", \"tlist\", or \"hlists\".");
- Option 3: Use double quotes for the outer string and single quotes inside.
scilab
Copy code
