acabo de instalar guibuider desde el modulo atoms en scilab 2026.1.0 y la instalcion acurre sin problemas, pero al meoento de habrir la ayuda se genrera el siguiete error.
Luego de aceptar la opcion se cierra el programa.
Please use english when posting. I have tested the installation of guibuilder on the macOS versions of Scilab 2025.1.0, 2026.0.1 and 2026.1.0. When clicking on the help button, I get the same dialog (The configuration file has been corrupted. Scilab needs to restart.). The problem remains after restarting Scilab,
Hello again,
I fixed a problem related to the help loading (this module has no documentation) and created a new version. You should be OK with
atomsSystemUpdate
atomsInstall guibuilder
