I need to use the ATOM fmincon. I have installed it in Fedora 44 both in Scilab 2026.0.1 and the latest Scilab 2026.1.0 (installed with the official .tar.xz),with its two dependencies via the command atomsInstall("fmincon"):
--> atomsGetInstalled()
fmincon 1.0.9 allusers SCI/contrib/fmincon/1.0.9 I
sci_ipopt 1.3.5 allusers SCI/contrib/sci_ipopt/1.3.5 A
apifun 0.4.3 allusers SCI/contrib/apifun/0.4.3 A
In order to learn fmincon(), I have downloaded the demos from its GitLab: demos · master · scilab / forge / fmincont · GitLab
--> exec('/home/blabla/fmincont/demos/fmincon_hesspattern.sce', -1)
Ă la ligne 287 de la fonction fmincon_ipopt (/home/blabla/scilab-2026.1.0/share/scilab/contrib/fmincon/1.0.9/macros/fmincon/fmincon_ipopt.sci ligne 297 )
Ă la ligne 406 de la fonction fmincon ( /home/blabla/scilab-2026.1.0/share/scilab/contrib/fmincon/1.0.9/macros/fmincon/fmincon.sci ligne 418 )
à la ligne 45 du fichier exécuté /home/blabla/fmincont/demos/fmincon_hesspattern.sce
ipopt : Taille erronée de l'argument d'entrée #1 : une seule structure attendue.
I have tried several other demos, and obtain always the same error about ipopt.
