Hi scilab team i tried following on windows and it gaves me errors
and just duration does not work anymore
duration(“00:00:26.310”,“hh:mm:ss.SSS”,“hh:mm:ss.SSS”)
duration: Unknown option “hh:mm:ss.SSS”.
what do i do wrong?
what do i do wrong?
Hello Pascal, it seems you double pasted the format in 2nd argument position instead indicating inputformat option :
→ duration(“00:00:26.310”,“InputFormat”, “hh:mm:ss.SSS”)
ans = [duration]
00:00:26.310
yes i did, but there was another error whilst i had blanks but still. should there be a problem, if both input and output are the same, should it not be recognised as it is?
its more a philosophical question, should it not know that there is an input and an output format, and if both are the same, it should not care?
There is no philosophical question here, this is a misuse of duration, as the valid syntaxes are well defined (see duration - Create a duration - duration in hours, minutes and seconds)
d = duration(h, m, s)
d = duration(h, m, s, ms)
d = duration(x)
d = duration(str)
d = duration(str, "InputFormat", inputFormat)
d = duration(..., "OutputFormat", outputFormat)
Ah, yes, now I see, it’s the placement of command and format twice of input and output.
Thanks, Pascal
