Dear,
due to some time discrepancy during experimental measurements,
I am currently investigating the difference between several time stamps.
These time stamps are generated via some LabWindows/CVI software, but the analysis I’d like to do with Scilab.
Two different time stamps are logged:
time stamp from Windows system … logged up to milli seconds
e.g.: YYYY, MM, DD, hh, mm, ss, ms -
time stamp generated by counting CPU ticks … logged up to micro seconds
e.g: YYYY, MM, DD, hh, mm, ss, ms, micros
In Scilab I would like to compare both time stamp using serial time
serialTime = datenum(...)
Now, I am not sure if datenum() handles only full seconds, so: What is correct ?
1.)
sec = ss + ms / (10^3) + micros / (10^6)
serialTime = datenum(YYYY, MM, DD, hh, mm, sec)
or
2.)
serialTime = datenum(YYYY, MM, DD, hh, mm, ss)
serialTime = serialTime + ms / (10^3) + micros / (10^6)
I assume it is 1.), but I do not know if datenum() truncates / rounds the seconds to “full seconds”.
Thank you,
