I am trying to find a way to display variable in engineering format with the exponent of 10 being a multiple of 3.
So that I can easily deduce the prefix like: giga, kilo, milli, micro, nano, pico.
Example of my code:
→ format(‘e’,24);
→ a = 10000; // 10k
→ a
a =
1.00000000000000000D+04
I would like to display a = 10.0000D+03.
Do you function for that or some format settings ?
Scilab uses the Engineering notation - Wikipedia, which has some disadvantages compared to SI notation, and there is no built-in feature to replace the actual display by a SI compliant display, you will have to code it yourself.
function out = eng(value, prefix, digits)
// adapted from https://jkorpela.fi/c/eng.html
arguments
value double {mustBeReal,mustBeScalar(value)}
prefix boolean {mustBeScalar(prefix)} = %f
digits double {mustBeInteger} = format()(2)-6
PREFIX_START=-24;
// Smallest power of then for which there is a prefix defined.
// If the set of prefixes will be extended, change this constant
// and update the table "prefix".
prefixstr=["y", "z", "a", "f", "p", "n", "μ", "m", "",...
"k", "M", "G", "T", "P", "E", "Z", "Y"];
PREFIX_END = PREFIX_START+(size(prefixstr,"*")-1)*3;
if value==0 || isinf(value) || isnan(value)
out = "";
return
if value < 0.0
sign_ = "-";
value = -value;
sign_ = "";
// correctly round to desired precision
expof10 = int16(round(floor(log10(value))));
value = value* 10^(digits - 1 - double(expof10));
display = fix(value);
fract = value-display;
if fract >= 0.5
display = display + 1.0;
value = display * 10^(double(expof10) - digits + 1);
if expof10 > 0
expof10 = (expof10/3)*3;
expof10 = ((-expof10+3)/3)*(-3);
value = value*10.0^double(-expof10);
if value >= 1000.0
value =value / 1000.0;
expof10 = expof10+3;
elseif value >= 100.0
digits = digits - 2;
elseif value >= 10.0
digits = digits - 1;
if ~prefix || (expof10 < PREFIX_START) || (expof10 > PREFIX_END)
out = sprintf("%s%.*fD%+03d", sign_, digits-1, value, expof10);
out = sprintf("%s%.*f %s", sign_, digits-1, value, prefixstr(1+(expof10-PREFIX_START)/3));
for example, for %pi*1e5 the function eng() above yields
--> eng(%pi*1e5,%f,10)
ans =
"314.1592654D+03"
--> eng(%pi*1e5,%t,10)
ans =
"314.1592654 k"
