Can anyone generate XCOS GPT?
Hello
I need GPT for XCOS and Scilab as there are many error
I didnot get any helpful response from Scilab team . I can pay who build my simulation without any error . Please help me. Teach me properly with my debug and error . For my simulation I can pay upto 10€ per hours who teach me XCOS coding.
Hi Vimsrocz
GPT is not always a solution, but I read your plead as a request for a good book and/or tutorial. Much material is unfortunately quite old. Maybe other people here can guide us to new material?
Googling, I found this one from 2013:
D-Booker published some books a while back (2014) in French. If you can speak French, this is an option. I can’t … so I wish they were translated to English. Here is my request:
With kind regards,
Claus
Thank you claus. I have my own develop block and the issue is developer has limited parameters which they check and release new version. Now due to some reason in older it was easily some file are generated and working but when we use new version the process doesnot follow.
Even apple consider multiple simulations and upgrade it by adding without changing formatting while in new version release by Scilab team is night mare to new people who use it. There is also issue teams when you post questions about XCOS there is no fruitful discussion or not lead to resolve issue. They should be concentrate in side of XCOS rather then only just one script. You can see most of XCOS questions are unanswered in community.
Even there is not tutor available who can guide or teach. Feeling like hell in student life.
Hi Vimsrocz
Maybe the idea for Scilab is that one should learn MATLAB Simulink first, and then once you are familiar with it, the shift to XCOS should be easy … but I think this is a bad approach.
IMHO Scilab should facilitate that one learns XCOS without first learning e.g. Simulink.
I never learned XCOS myself, simply because of lack of tutorial. I am sorry that I am unable to help you. The before mentioned tutorials is as far as I got, then I had to stop because the learning curve is too steep for me (I didn’t want to first learn French, then XCOS).
MATLAB plus Simulink comes with a ca. 5000 - 10000 EUR price ticket (depending on modules). As a private person, this is not feasible.
With kind regards,
Claus
I can do it in Simulink easily. I have learn Simulink in 2018. MATLAB is far better with Simulink than XCOS because console gives detailed error message and easily locate the error. GUI means masking in Simulink is easy then in XCOS GUI means graphics parameters.
Not only this model parameters are easily setup while in XCOS it says xx error .
I can do it in Simulink but my professor want it in XCOS which is worse for me. Every company uses MATLAB so only for this project I have to do in XCOS.
They have to provide debug block with details like MATLAB/Simulink has like attach some block with own develop block which gives you data why block is not performing , in which parameters error is lying like model or graphics.
You can give me task and I will do it in Simulink then will you help me with XCOS. Let’s make a deal.
