Hi Scilab Team i recently played a little bit with try and catch. And i struggle a little bit because it could not handle the semicolon for line ending. And afterwards, when i removed semikolon it find end anymore. It seems that the try-catch -end flow is a little bit inconsitence or stable enough.
Hi Pascal,
Could you post examples of your try?
This will help us on debugging the issues. Thanks !
→ try
out1(i,:)=[strsplit(stdout1($-6),[" ","="])(3),strsplit(stdout1($-6),[" ","="])(5),strsplit(stdout1($-6),[" ","="])(9),strsplit(stdout1($),["= ","ms"])(2),strsplit(stdout1($),["= ","ms"])(4),strsplit(stdout1($),["= ","ms"])(6)]; catch out1(i,:)=[] end
Undefinierte Variable: i
→ try;
try;
Fehler: 1.1->2.1 syntax error, unexpected end of line
These two errors are expected:
- the
iis not defined but used, and error is produced - the
try;is starting atryblock and ending it with;without any instruction.
Yes you have right i may confused the end of line syntax with the wright if “statement” ; and try “statement” ;. Yes that was a rule error of mine.
M.f.G. Pascal
