Hi, everyone!
Please, I have ZBBE (end of this message), an array of rational polynomials to be simplified. I’ve tried to use commands “simp_mode (%T)” before the equation that defines ZBBE and “simp(ZBBE)”, also separating numerators and denominators, and ZBBE has kept the same.
So I’ve tried to use “gcd” command, with the following script:
mdc1=gcd([ZBBE(k,1).num ZBBE(k,1).den]);
if mdc1~=1
simp_num=ZBBE(k,1).num./mdc1;
simp_den=ZBBE(k,1).den./mdc1;
ZBE(k,1)=simp_num/simp_den;
Now I have ZBE (also at the end of this message). Some irreducible rational polynomials have kept the same as I expected. Others, like ZBBE(1,1) was properly simplified. But I have a problem with the last one, ZBBE(23,1), which became of even grater degree.
Please, could someone solve my problem or at least explain to me what is going wrong? I thank you a lot.
-> ZBBE
ZBBE =
0.0000124 +1.262D-09s +8.496D-12s² +4.316D-16s³ +1.453D-18s⁴
4.234D-08 +2.052D-12s +2.896D-14s² +7.018D-19s³ +4.952D-21s⁴
3.135D+08 +200000s
353004.51 +1941.1718s +s²
0.0000124 +1.284D-09s +8.645D-12s² +4.469D-16s³ +1.504D-18s⁴
4.234D-08 +2.088D-12s +2.947D-14s² +7.266D-19s³ +5.127D-21s⁴
1.818D-13 +2.236D-17s +1.505D-19s² +9.255D-24s³ +3.115D-26s⁴
3.240D-16 +1.636D-18s +4.695D-22s² +1.355D-24s³ +1.388D-28s⁴
+2.804D-31s⁵
6.614D+11 +2.556D+08s +166666.67s²
6613756.6s +2556.2372s² +s³
0.0000008 +6.435D-10s +3.922D-13s² +1.046D-16s³
8.984D-12s +7.078D-15s² +2.987D-18s³ +6.274D-22s⁴
0.014861s +0.0000095s²
2.972205 +0.001893s +7.431D-08s²
1.135D+08 +166666.67s
96457.316 +951.74433s +s²
7.375D+08 +583333.33s
1839060.2 +4404.5491s +s²
1.601D-13 +2.236D-17s +1.325D-19s² +9.255D-24s³ +2.743D-26s⁴
3.240D-16 +1.441D-18s +4.695D-22s² +1.193D-24s³ +1.388D-28s⁴
+2.469D-31s⁵
489383.56s +845s²
9411222.3 +16592.466s +s²
2.987D+11 +1.439D+08s +111111.11s²
3882915.2s +1871.042s² +s³
1.632D-17s +2.601D-19s² +8.777D-22s³
4.410D-16 +7.029D-18s +2.387D-20s² +1.425D-24s³ +3.456D-27s⁴
0.1760929s +0.0002869s²
8.804645 +0.0143449s +0.0000009s²
1.0174757s +0.0023123s²
14.535367 +0.0330322s +0.0000071s²
1.125D-17s +1.176D-19s² +2.382D-22s³
2.250D-16 +2.351D-18s +4.866D-21s² +5.569D-25s³ +7.657D-28s⁴
2.644D-13 +6.668D-19s² +3.806D-25s⁴
6.480D-16 +2.115D-18s +1.634D-21s² +3.693D-24s³ +9.328D-28s⁴
+1.612D-30s⁵
449410.95s +816s²
7022046.1 +13096.5s +s²
0.0001426 +0.0000005s
2.139D-09s +3.060D-12s²
1.192D-17s +1.253D-19s² +2.553D-22s³
2.250D-16 +2.364D-18s +4.924D-21s² +5.935D-25s³ +8.205D-28s⁴
0.1937022s +0.0003156s²
8.804645 +0.0143449s +0.000001s²
1.417D+11 +23864070s +111111.11s²
2.435D+08 +1275510.2s +405.68919s² +s³
2.744D-18s +2.898D-20s² +6.638D-23s³
3.920D-16 +4.140D-18s +9.505D-21s² +1.475D-25s³ +2.478D-28s⁴
--> ZBE
ZBE =
4.248D-12 +4.316D-16s +1.453D-18s²
1.448D-14 +7.018D-19s +4.952D-21s²
3.135D+08 +200000s
4.322D-12 +4.469D-16s +1.504D-18s²
1.473D-14 +7.266D-19s +5.127D-21s²
+2.804D-31s⁵
3.218D-10 +1.267D-13s +1.046D-16s²
3.539D-15s +1.394D-18s² +6.274D-22s³
+2.469D-31s⁵
489383.56s +845s²
3.094D-20s +2.382D-22s²
6.188D-19 +4.764D-21s +2.784D-25s² +7.657D-28s³
2.308D-19 -4.793D-37s +3.806D-25s²
5.657D-22 +1.846D-24s +9.328D-28s² +1.612D-30s³
449410.95s +816s²
3.813D-16s +6.771D-18s² +3.820D-20s³ +6.638D-23s⁴
5.448D-14 +9.673D-16s +5.460D-18s² +9.526D-21s³ +1.820D-25s⁴
+2.478D-28s⁵
