Scilab 2025.1.0 crash on win11
Good morning to all,
I recently installed Scilab 2025.1.0 on a Windows 11 Enterprise (24H2) and it often crashes. Even the 2025.0.0 version has the same behavior. When running a script, Scilab (both Desk and console) closes randomly and I cannot understand the reason.
Then I installed Scilab 2025.1.0 on a different machine, with win11 home and it works perfectly.
So, I guess the problem is not the script itself (it worked even under with Scilab 5.5.2) but it is probably related to the Scilab installation, or the OS or a OS related issue.
Did you experience anything similar? Any suggestion?
Thank you
MAx
I tried to install Scilab 2026.0.0 on the same win11 enterprise PC but it crashes randomly as the previous versions. The Windows “event monitor” always reports the same error, as shown in the picture below. The guilty seems to be the ucrtbase.dll library. Giving a look in the internet it comes out that a possible solution could be to update the Microsoft Visual C++ redistributable. I did this to the 14.44.35211 release but nothing change. I would say that the above mentioned library is not affected by this update.
Is there any other suggestion? Is there someone who is experiencing the same?
Thank you
Hi max
Reading your messages made me realize, I haven’t tested or run any Scilab code since I installed Windows 11 last month, so I did that. I ran a bunch of scripts and all of them works fine, no crash. I found an old script (2017) and with a few modifications was able to run that as well.
Since I cannot reproduce, I think you’ll have to provide more information for anybody to be able to provide you with any kind of help. The screenshot from the error itself doesn’t help in reproducing your problem.
I am using Scilab 2025.1.0.
With kind regards,
Claus
Hi Claus,
thank you for your answer. It is difficult to give additional details because actually I have not yet clearly understood where the problem is. For example, if I run the script (with Scilab 2025.1.0) you can download at the following link, Scilab frequently crashes but never at the same “i”. Sometime it works.
The message I get in the “Microsoft event viewer” is always similar to the one in the picture above.
I would conclude that the problem is not in the script itself but rather in the Scilab installation or, most probably, in Win11. I am currently using a company PC where the Microsoft Visual C++ redistributable has been updated, but without any satisfaction.
I feel a bit lost, being unable to reproduce the error. I doubt that there could be a “bad interaction” between Scilab when running and some other software which causes the crash, but no idea how to identify it more clearly.
I keep you informed if I get any news.
Best
MAx
Hi Max,
Your ucrtbase.dll seem more recent than mine (eg. loaded by Scilab). It may be due to a crash on Scilab C code ; it might be hard to debug without an input script. Could you try to downgrade the ucrtbase.dll ?
s
For the record, this library was also identified in other crashes (see https://scilab.discourse.group/t/scilab-2024-2025-crashes-when-running-xcos-simulation-while-2023-works-fine).
Stephane et David,
merci beaucoup pour vos responces!
Actually, I knew this thread and I already tried:
  • to set the compatibility of the Scilab executable files (both Deck and Console) to win8 as proposed, but the problem of unexpected crashes is not solved at all.
  • to update the “Microsoft Visual C++ redistributable” to the last version available, as suggested online to solve similar problems even for other software, but even in this case the problem persists.
    I also tried to disinstall the redistributables and install older versions, but still nothing changed.
    The “ucrtbase.dll” has never been affected in my PC. It always is the 10.0.26100.6899. I am not an expert but, maybe it comes with the OS installation?
Questions:
  • who is putting the ucrtbase library in the “.\Windows\System32” and how could I downgrade it to a desired version?
  • Is there any recommendation about the system requirements or packages that have to be present in win to properly run Scilab?
Have a nice day
Thank you
MAx
I have also experienced problems with Win 11 Enterprise, ever since the Windows update of October 2025 - most of the time Scilab crashed on start-up, or by the time I loaded an image into my image processing program. Before this update, Scilab 2024-2026 were running just fine. I finally found that Scilab 2023.1.0 still works, however, it does not have the fast graphics engine introduced with Scilab 2024 that I dearly miss! I have uninstalled all MS Visual-C++ compilers
BTW At home I can still run Scilab 2026 on my private computers under the now obsolete Win 10. I don’t have a computer running a Win 11 installation, so I haven’t been able to test Scilab under a non-enterprise version of Win 11. I guess I’ll keep running Win 10 for now…
Suggestions on the web to only keep the latest version of MS Visual C++ did not work either. I have now uninstalled all MS Visual C++ software, but still: Scilab 2023 works, Scilab 2024+ crash.
In the meantime I have upgraded to scilab-2026.0.1. Now I can open the Scilab IDE without it crashing and can run simple scripts under Win 11 Enterprise. However, my image analysis program still crashes whenever I try to read an image. A typical image size is 1000 x 1000 pixels. My program runs under Win 10 and also under Win 11 Pro. I hope that the Scilab team will be able to further improve things with the Enterprise version. My program is available on Github (see link below) with an example image, if anybody wants to take a look. I have little knowledge about Windows, in particular about differences between Home and Pro editions versus Enterprise.
