Scatter3d and single point coordinates
Dear,
maybe I am just confused, but:
I try to follow the order of appearance of a set point x-y-z coordinates.
I other words: I would like to show each point one after another, to check if they appear in the correct order / sequence.
Background: Many sensors are installed in a specific order but they are displayed in a different order.
To have a connection between installation and display I would use a look up table (LUT), e.g.: installed sensor #1 appears in the display at position 32.
Now, if I want to display the sensors in the order they are appear, I can do that as follows:
for i = 1:nrOfSensors
    plot(xc_sensors(sensor_LUT(i)), zc_sensors(sensor_LUT(i)), '-obl');
    sleep(50);
// xc_sensor = x-coordinate of installed sensor
// zc_sensor = z-coordinate of installed sensor
However, if I want to do this in a 3D plot I kind of struggle.
scatter3d, plot3d, etc seem to accept only vectors but no single scalars?
e.g.:
scatter3d(xc_sensors(sensor_LUT(i)),yc_sensors(sensor_LUT(i)),zc_sensors(sensor_LUT(i)));
does not work … so: how to plot a single point in 3D ?
I do can do:
    x = xc_sensors(sensor_LUT(i));
    y = yc_sensors(sensor_LUT(i));
    z = zc_sensors(sensor_LUT(i))
    scatter3d([x x], [y y], [z z]);
    sleep(50);
but is this the way to go?
Thank you,
