Stefan
January 19, 2024, 7:00am
1
I have to replace the obsolete function “str2code”, but it doesn’t work.
Here is the old version:
KR=str2code(part(Scherung(7,2),2:3));
And then I tried this:
KR=ascii(part(Scherung(7,2),2:3));
But this line will create an index-error message:
if KR(2,1)==40 then …
Any idea? Many thanks.
Can you show the content of
please ? I guess this is just a problem of vector shape, i.e. you are expecting a column vector but ascii() yields the transpose. So you should just rewrite your test so that the actual shape (row or column vector) does not matter, i.e.
if KR(2)==40 then
Stefan
January 19, 2024, 8:19am
3
Hello mottelet, “Scherung” is an Excel-Worksheet, and the content of "Scherung(7,2) is a string of two chars, in this example the string “A1”.
OK, that’s what I said
--> ascii(part("A1",2:3))
ans =
49. 32.
so a column vector, so use adequate matrix index (1,2) or generic vector index (2)
Hello Stefan,
I’m not sure what do you want to do with “A1” but if the goal is to convert it to [i,j] form like “A1” => [1,1], “Z64” => [64, 26]
I write something some years ago (updated version):
function ret = excel2scilab(cell)
ret = [];
b = [1 26];
cell = convstr(cell, "u");
[_, _, _, d] = regexp(cell, "/([A-Z]+)([0-9]+)/");
a = ascii(d(1)) - ascii("A") + 1;
c = sum(a($:-1:1) .* b(1:size(a, "*")));
ret = [strtod(d(2)) c];
excel2scilab("A4")
ans =
4. 1.
excel2scilab("AT521")
ans =
521. 46.
excel2scilab("TA46")
ans =
46. 521.
