Dear all,
removing moving objects from a scene can be achieved by using a stack of images and apply a median filter to a vector that hold the pixel values of every at the same pixel-coordinate.
The result of the median would be the output image pixel value at that very pixel-coordinate.
Out of curiosity I tried to apply this in Scilab with the IPCV-toolbox … mainly to read and show RGB images.
Below you may find an example code, which seem to do what I expect…however it contains two
for-loops, for iterating through the pixel locations.
This is very slow and i wonder if there is a way to avoid these.
I tried to work straight with
output = median(input, 'anInteger') // anInteger = 1,2,3
but with no real success.
The principle idea is example wise explained here:
Thank you,
inDir = get_absolute_file_path('imageStack.sce');
chdir(inDir);
// get the file names
imgDir = inDir + 'SubFolderThatContainsAllImages';
imgFiles = findfiles(imgDir);
// get the number of images
nrOfImg = max(size(imgFiles));
// build a vector that contains all absolute image paths ... only for convenience
for i = 1:nrOfImg
imgPath(i) = imgDir + '\' + imgFiles(i);
// init image
imgIn = imread(imgPath(1));
// get the image size = size of output image
[imHeight imWidth imCh] = size(imgIn)
// initiating the RGB-planes of the output image
imgOut_R = zeros(imHeight, imWidth);
imgOut_G = zeros(imHeight, imWidth);
imgOut_B = zeros(imHeight, imWidth);
// initiating the output image
imgOut = zeros(imHeight, imWidth, 3);
// building the image stack
for i = 1:nrOfImg
disp(i);
imgStack(i,:,:,: ) = imread(imgPath(i)); // note: (i, :,:,:) creates a smiley in the post
// extracting the according RGB-planes from each image
pxVals_R = imgStack(:,:,:,1);
pxVals_G = imgStack(:,:,:,2);
pxVals_B = imgStack(:,:,:,3);
// iterating through all pixel locations to find the median value
// from all images at each specific pixel location
// do this for each color channel
for j = 1:imWidth
disp(j);
for i = 1:imHeight
imgOut_R(i,j) = median(pxVals_R(:,i,j));
imgOut_G(i,j) = median(pxVals_G(:,i,j));
imgOut_B(i,j) = median(pxVals_B(:,i,j));
// compose the output image
imgOut(:,:,1) = imgOut_R;
imgOut(:,:,2) = imgOut_G;
imgOut(:,:,3) = imgOut_B;
// show the result
imshow(imgOut./256); // imshow requires range 0-1
printf("end of script");
