Large table handling and visualization
I’ve been noticing strange behaviours around large table tres as shown in screenshot:
only the first variable is thrown short in the console, is this as expected?
Another issue maybe related to previous: To get summary of specific group of variables I had to copy data into new table (because extraction failed) and in this case the summary is running properly as shown below.
summary(tres, "default", ["Inba","Current : In"]) //pb, wrong results
tI= table(tres(["Inba","Current : In"]), "VariableNames", ["Inba","Current : In"]);
summary(tI)
Any idea about the reason why is failing to summarize the selected items in original tres table where every statistic indicators are wrong for both variables ?
Another issue around accessing the data in tres selected variables (rank 17 and 18 in the 60 variables) : access with variable names is ok while access with rank is failing as shown below
Thank you for your comments,
After other tests it seems there are two separate issues:
  • one linked to the variables selection feature of summary()
  • one linked to original tres table creation, VariableNames is to be supplied as a row vector of names for proper behaviour.
I’m reporting the issues in gitlab.
