I want to import a csv file and plot some of the column data. Is there a example how to do this. I could do it with the older import tool but uiimport is not the same as the older uiSpreadsheet.
what about csvRead and plot ?
I reinstalled version 6.1.1 to see how uiSpreadsheet and uiimport differ. I see there are no options to convert in uiimport; in my case, I converted to double in uiSpreadsheet.
Here is the function generated by uiSpreadsheet. This creates a variable containing values of type double.
clear importdata;
function [data] = importdata(filename)
data = csvRead(filename, ";", ",", "double");
[data] = importdata("F:\2857-0570_Rog\20250212_144220_log.csv"); `
Here is the function generated by uiimport. This creates a variable containing a table which cannot be plotted without further processing.
clear import_20250212_144220_log;
function [data] = import_20250212_144220_log(filename)
opts = detectImportOptions(filename, "Delimiter", ";", "Decimal", ",");
data = readtable(filename, opts, "VariableNames", ["Date","Time","L1 Current / A","L2 Current / A","L3 Current / A","L1 Voltage / V","L2 Voltage / V","L3 Voltage / V","L1 Active Power / W","L2 Active Power / W","L3 Active Power / W"]);
data.Date.format = "dd.MM.yy";
data.Time.format = "hh:mm:ss";
data = import_20250212_144220_log("F:\2857-0570_Rog\20250212_144220_log.csv");
Is there any tool similar to uiSpreadsheet in later versions of scilab?
