How to model power electronics converter in Xcos?
I would like to simulate a power electronic converter in Scilab/Xcos. The converter consists of several elements of below given type i.e. the IGBT with an antiparallel diode
My intention is to simulate this element in an abstract manner. It means simulate the transistor as an ideal switch i.e. circuit element with below given features
  • zero resistance in the on state
  • infinite resistance in the off state
  • ability to transfer current only in one direction
  • instant transition between the on and off state based on the control signal
Simulate the diode as an ideal valve i.e. circuit element with below given features
  • inifinite resistance in the off state
  • ability to transfer current in one direction
  • transition into the on state based on voltage between anode and cathode
    and transition into the off state based on zero current
May I ask you for an advice what is the most suitable way how to model this element in Scilab/Xcos?
Did you have a look to the “Electrical” palette in Xcos ? I think that both (Modelica) components are available there.
thank you very much for your reaction. Yes, the “Electrical” palette contains several types of the transistors and some diode also. The problem is that the elements require a buch of parameters. I am not able to specify those parameters. I would like to abstract the power electronics circuit from some specific devices and I would like to analyze the raw dynamic of the circuit.
What do yo mean by
? If abstracting means using equations, you will also need parameters, don’t you think ?
Yes, but in the first approximation only the parameters of the passive elements (inductors, capacitors) not the transistors and diodes.
Is it a homework/assignment ?
No, it isn’t. It’s part of my self study of the power electronics and the electrical drives.
In that case your problem is not Scilab specific but rather a modeling issue. Considering the features you expect for your ideal components, everything should be doable with switches and other kinds of blocks handling events.
You are describing a discontinuous model.
Although that is the simplest way to model the IGBT and diode, this is problematic in most simulation environments.
Continuous solvers require continuous models. Otherwise the solvers may crash
The solution is to define continuous transitions between discrete states.
During simulation these transitions should last short enough to appear as “discontinuous” compared to the simulation duration.
This may work under the condition that the duration of each transition consists of multiple time steps.
No, continuous solvers do not require continuous models, provided they can be stopped and restarted at discontinuites.
For example, Xcos uses continuous solvers, but discontinuous components are handled by generating discrete events, where the ODE solver (or DAE solver, when the diagram includes acausal blocks) stops then restarts. In fact every ODE/DAE solver can handle discontinuous right hand sides, provided that the discontinuites can be detected as events (typically, zero crossing functions), so that the solver can be stopped (this is an option in the event finding mecanism), then restarted just after crossing the “ring of fire”.
