Hi Scilab Team,
how can i plot a polyline by plot(x,y) over a picture plotted by uicontrol.
is it the order of the code, first plot than picture or is there some layer function?
M.f.G. Pascal
Hi Scilab Team,
M.f.G. Pascal
There is no way to plot over an uicontrol image. However, this is possible if the image is displayed by using Matplot, but the image has to be read by using imread, which implies that you must have IPCV or Scicv toolbox. For example:
clf
http_get("https://www.fileformat.info/format/jpeg/sample/0c047d42fdfb419e86c594f0f7ad3ce1/SPACE.JPG","space.jpg",follow=%t);
x=imread("space.jpg");
Matplot1(x,[0 0 10 2]).data=x;
t=0:0.01:10;
plot(t,1+sin(2*t),'r',"thickness",2)
the recursive assignment above (Matplot1 call) is necessary because there is a bug in Matplot1 implementation.
ok, i hoped that there was something without using an Atom-package.
thank for the quick reply. ![]()
M.f.g. Pascal
Well,
as mentioned above: Using an Image Prcessing toolbox is the easy way.
But: If you strictly want to avoid that you may try this:
f = figure();
x = linspace(0,20,200);
plot(x,sin(x))
e = gce();
c = e.children;
h = xstring(0,-1,"$\scalebox{1}{\includegraphics{path-to-your-image}}$");
c.data(:,3) = 0.1; // <<<==== HERE, use the "z" value > 0, to put the plot "on top" of the image
c.thickness = 2;
Found this workaround here:
BR
does it also works with uicontrol than xstring?
works
like you propose.
with JCEF and Browser i could manage this:
f1 = figure(“infobar_visible”,“on”,“toolbar_visible”,“on”,“dockable”,“on”,“menubar_visible”,“on”,“default_axes”,“off”,“axes_size”,[1200,900],“layout”,“border”,“resize”,“on”,“tag”,“com”);
fr = uicontrol(f1, “style”,“frame”,“backgroundcolor”, [1 1 1],“layout”,“border”);
html=[...
"<!DOCTYPE html>"
"<html lang=''en''>"
"<head>"
"<meta charset=''UTF-8''>"
"<meta name=''viewport'' content=''width=device-width, initial-scale=1.0''>"
"<title>Overlay Images</title>"
"<style>"
" .image-container {"
" position: fixed;"
" right:0;bottom:0;"
" width: 903px;"
" height: 638px;"
" .background {"
" position: fixed;"
" z-index: 1;"
" width: 100%;"
" height: 100%;"
" opacity: 1.0;"
" .foreground {"
" position: fixed;"
" left:-192px;bottom:-33px;"
" z-index: 2;"
" width: 130%;"
" height: 118%;"
" opacity: 0.5;"
"</style>"
"</head>"
"<body>"
" <div class=''image-container''>"
" <img src=''C:\Users\buehlpas\Documents\Scilab\FH_50.png'' alt=''Background Image'' class=''background''>"
" <img src=''C:\Users\buehlpas\Documents\Scilab\GV_VWI.svg'' alt=''Foreground Image'' class=''foreground''>"
" </div>"
"</body>"
"</html>"];
mputl(html,TMPDIR+“/com.html”);
browser = uicontrol(fr,“style”,“browser”,“debug”, “on”,“string”,TMPDIR+“/com.html”,“callback”, “”,“tag”, “browser”);
as an example
