Dear,
opacity in graphs (and images) seem to pop up as a request once in a while.
A recent question (as of 05.2024) , see:
Well, an older discussion pointed out to use scicv, but no final statement about opacity was done back then.
https://lists.scilab.org/pipermail/users/2019-March/014858.html
The recent request made me think again, and I put together some code.
If I am not to wrong, scicv do can handle opacity, but it is a bit tricky and not well documented.
I used scicv 0.6.2.
Analyzing the saved images with IrfanView, the 3-channel image seem to have no alpha channel, but the 4-channel image does.
// PURPOSE: Play around with opacity of images
// BACKGROUND: try to use scicv toobox to create images with opacity
// INPUT: https://docs.opencv.org/3.4/d4/da8/group__imgcodecs.html (some openCV source)
// OUTPUT: some generic images
// DEPENDECIES: scicv toolbox
// PREPARE SCILAB
clc();
clear();
close();
// SUBROUTINES none
// DEFINES
OUT_DIR = 'D:\Scilab_Uebungen\Try_Opacity_with_Scicv' + '\'
// CODE
scicv_Init();
// load image as 3 channel image
img_1 = imread(getSampleImage("lena.jpg"));
img_2 = new_Mat(size(img_1, 'c'), size(img_1, 'r'), CV_8UC3, 128); // img1 is of size [255 255]
img_Out = add(img_1, img_2);
// Create 3 channel images (BGR)
backgroundColor = [255, 0, 0]
imgNew_1 = new_Mat(255, 255, CV_8UC3, backgroundColor);
backgroundColor = [0, 0, 255]
imgNew_2 = new_Mat(255, 255, CV_8UC3, backgroundColor);
imgNew_Out = add(imgNew_1, imgNew_2)
// create 4 channel images (ABGR (?) )
backgroundColor = [25, 255, 0, 0]
imgNew_1_A = new_Mat(255, 255, CV_8UC4, backgroundColor);
backgroundColor = [25, 0, 0, 255]
imgNew_2_A = new_Mat(255, 255, CV_8UC4, backgroundColor);
imgNew_Out_A = add(imgNew_1_A, imgNew_2_A)
// display images
subplot(3,3,1)
matplot(img_1);
subplot(3,3,2)
matplot(img_2);
subplot(3,3,3)
matplot(img_Out);
subplot(3,3,4)
matplot(imgNew_1);
subplot(3,3,5)
matplot(imgNew_2);
subplot(3,3,6)
matplot(imgNew_Out);
subplot(3,3,7)
matplot(imgNew_1_A);
subplot(3,3,8)
matplot(imgNew_2_A);
subplot(3,3,9)
matplot(imgNew_Out_A);
// export images
imwrite(OUT_DIR + "RGB.png", imgNew_Out);
imwrite(OUT_DIR + "RGBA.png", imgNew_Out_A);
// delete images
delete_Mat(img_1);
delete_Mat(img_2);
delete_Mat(img_Out);
delete_Mat(imgNew_1);
delete_Mat(imgNew_2);
delete_Mat(imgNew_Out);
delete_Mat(imgNew_1_A);
delete_Mat(imgNew_2_A);
delete_Mat(imgNew_Out_A);
// END OF SCRIPT
printf("\n");
printf("REACHED END OF SCRIPT.");
