Celebrate the beauty of mathematics with this golden spiral created using Scilab.
Change the values to explore how multiple Fibonacci spirals unfold from a single point, forming fascinating golden patterns found in nature, from seashells to sunflowers!
Have fun!
Here is the script to run:
// ----- Fibonacci sequence -----
function fib = fibonacci_seq(n)
fib = ones(1, n);
for i = 3:n
fib(i) = fib(i-1) + fib(i-2);
// ----- Draw one Fibonacci spiral -----
function [x, y, theta, r] = draw_spiral(n, k, theta, angle_, color_)
x = zeros(n, 1); y = zeros(n, 1);
r = 1;
for i = 1:n
x(i) = r * cos(angle_);
y(i) = r * sin(angle_);
angle_ = modulo(angle_ + theta, 2*%pi);
r = sqrt(i + 1);
e = plot(ax, x, y, ".");
c = color_ * 255;
e.mark_foreground = color(c(1), c(2), c(3));
e.tag = "plot" + string(k);
// ----- Draw all spirals -----
function draw_all_spirals(ax, n, k, theta)
delete(ax.children)
drawlater();
colors = [0.95 0.8 0.3;
0.9 0.7 0.2;
0.85 0.65 0.15;
0.8 0.6 0.1;
0.75 0.55 0.1;
0.7 0.5 0.05;
0.95 0.85 0.45;
0.9 0.75 0.35;
0.85 0.7 0.3;
0.8 0.65 0.25;
0.9 0.8 0.4;
0.85 0.7 0.2];
for i = 1:k
angle_ = (i-1)*(2*%pi/k);
draw_spiral(n, i, theta, angle_, colors(i,:));
ax.axes_visible = "off";
ax.isoview = "on";
ax.tight_limits = "on";
ax.box = "off";
mi = floor(min(ax.children.children.data))-1;
ma = abs(mi);
ax.data_bounds = [mi mi; ma ma];
ax.margins = zeros(1, 4);
drawnow()
function animate_spirals()
try
while %t
n = round(strtod(get("value_n", "string")));
k = round(strtod(get("value_k", "string")));
ax = get("spiral_axe");
st = ax.userdata;
if (n < 5 | n > 1000 | isnan(n)) then
n = st.n;
set("value_n", "string", string(n));
if (k < 1 | k > 12 | isnan(k)) then
k = st.k;
set("value_k", "string", string(k));
// fibonnaci sequence
fib = fibonacci_seq(n+1);
// ratio - approximation of the Golden Ratio
phi = fib(2:n+1)./fib(1:n);
theta = 2.0 * %pi * ( phi - 1.0 ) ./ phi;
theta = theta($);
rot = 0;
if (st.n <> n | st.k <> k) then
st.n = n;
st.k = k;
st.rot = rot;
set("spiral_axe", "userdata", st);
while round(strtod(get("value_n", "string"))) == n && round(strtod(get("value_k", "string"))) == k
if get("stop_btn", "userdata") then
continue
rot = rot - %pi/180; // rotation step (~20 s per full rotation)
for i = 1:k
base_angle = (i-1)*(2*%pi/k) + rot;
e = get("plot" + string(i));
x = zeros(n, 1); y = zeros(n, 1); angle_ = base_angle;
r = 1;
for i = 1:n
r = sqrt(i + 1);
e.data = [x, y];
st.rot = rot;
sleep(100);
catch
// window closed
lasterror();
function animation()
running = ~get("stop_btn", "userdata");
if running then
set("stop_btn", "string", "Play");
set("stop_btn", "string", "Stop");
set("stop_btn", "userdata", running);
function fibonacci_gui()
close();
fig = figure("figure_position", [247, 167], ...
"background", -2, ...
"resize", "off", ...
"axes_size", [730 710], ...
"default_axes", "off", ...
"infobar_visible", "off", ...
"figure_name", "Fibonacci Spiral — (Fibonacci Day — Nov 23)", ...
"layout", "border", ...
"visible", "off", ...
"tag", "fig_fib");
axe_fr = uicontrol(fig, ...
"style", "frame", ...
"backgroundcolor", [1 1 1], ...
"tag", "axe_fr", ...
"constraints", createConstraints("border", "center"));
st = struct("n", [], "k", []);
ax = newaxes(axe_fr);
ax.tag = "spiral_axe";
ax.userdata = st;
top_fr = uicontrol(fig, ...
"constraints", createConstraints("border", "top", [10 70]));
uicontrol(top_fr, ...
"style", "text", ...
"string", "Fibonacci Spiral — (Fibonacci Day — Nov 23)", ...
"fontsize", 15, ...
"horizontalalignment", "center", ...
"backgroundcolor", [1 1 1]);
bg = [248 248 248]./255;
"backgroundcolor", bg, ...
"constraints", createConstraints("border", "bottom", [10 60]));
// n - number of fibonacci terms
uicontrol(fr, ...
"string", "Number of Fibonacci terms", ...
"fontsize", 11, ...
"position", [30 20 150 30]);
uicontrol(fr, ...
"string", "<html>5 ≤ n ≤ 1000", ...
"fontsize", 11, ...
"fontangle", "italic", ...
"position", [30 7 130 17]);
uicontrol(fr, ...
"style", "edit", ...
"string", string(500), ...
"fontsize", 11, ...
"tag", "value_n", ...
"horizontalalignment", "right", ...
"enable", "on", ...
"position", [185 20 100 25]);
// k - number of spirals
uicontrol(fr, ...
"string", "Number of spirals", ...
"fontsize", 11, ...
"position", [350 20 100 30]);
uicontrol(fr, ...
"string", "<html>1 ≤ k ≤ 12", ...
"fontsize", 11, ...
"position", [350 7 70 17]);
uicontrol(fr, ...
"string", string(4), ...
"fontsize", 11, ...
"tag", "value_k", ...
"enable", "on", ...
"position", [460 20 100 25]);
uicontrol(fr, ...
"style", "pushbutton", ...
"string", "Stop", ...
"callback", "animation()", ...
"tag", "stop_btn", ...
"callback_type", 10, ...
"userdata", %f, ...
"position", [600 20 100 25]);
fig.visible = "on";
fibonacci_gui()
animate_spirals()
