Code generation using X2C
I am using X2C with Scilab/Xcos to design a modular model that contains multiple SuperBlocks, for example:
  • SINE_GENERATOR
  • LED_LAYER
  • OSCILLATOR
When I generate code from the main Xcos model, X2C produces a single combined C file containing all the code for every block.
I would like to generate separate C and header files for each SuperBlock (for example LED_LAYER.c/.h, SINE_GENERATOR.c/.h, etc.) so that each functional layer can be reused as an independent module in my embedded project.
Could someone please clarify:
