2027.0.0 multiple launch
In windows file explorer
  • double click on file_A.sce launches Scilab, and opens file_A in Scinotes
  • next, double click on file_B.sce launches another Scilab instance, including another Scinotes
  • file_A and file_B appear in both Scinotes instances
The correct behavior should be a single Scilab-Scinotes launch, opening the two files in a single Scinotes window.
Scilab: 2027.0.0
OS: Windows 11 Pro 26H2. Compilation 26300.9711. Windows experience pack 1000.26100.372.0
Dear @javika ,
Thanks for your feedback.
We are no able to reproduce this behavior. Did you change anything after a standard installation of Scilab?
Did the same behavior happen with Scilab 2026.1.0?
Solved.
The machine had also installed Java (jre-8u503-windows-x64) prior to Scilab 2027.0.0, when Java was uninstalled the problem dissapeared.
