I’m currently using xcorr for signal/data measurements processing purpose, around time delay analysis and I’m wondering about the bibliographic references and theoretical details that inspired the current implementation : is there any book or article you may pointing out (beyond the example of the D-booker french book Vol.3) ?
Thank you
