Inconsistency between delta block and register shift output
the block diagram below should output the same signal since a delay block is equivalent to a shift register and a clock.
after running the simulation
note that for the delay block discretization time step =0.1
register initial state 10x0
the clock step linked with the shift register is also 0.1
and the shift register is initialized with 10x0
Is it a continuous time simulation ?
yes it should be
how can I find out
Well, I am not sure about what Xcos does for this kind of diagram where there is no differential block. Did you try to increase the simulation time ?
OMG! I increased the simulation time from 5s to 50s and the two signals were identical
could you see the reason behind this?
thanks
maybe @davidcl could answer.
Hi Yuri and welcome here,
This is a classic aliasing issue due to how Xcos/Scicos handle events. In your schema, you have two clocks with the same frequency but not synchronized. This is not a continuous schema in that aspect.
There are 3 events: the scope clock, the shift register clock and the pulse inner clock.
The scope clock will be propagated and applied to the delay and the mux.
To better understand, I suggest switching the scope to use marks instead of lines; you will then get the exact computation point.
To synchronize the clocks, either connect the shift register to a clock derived from the scope (using freq_div) or use a single shared clock with only SampleCLK blocks.
Dear davidcl,
thank you for being so helpful!
if I understand you well, a good practice is to use 1 clock per diagram
set this clock with high frequency to the scope, and then link it to other components via freq_divs.
please be advised when I deleted the shift clock and linked the shift register to the scope one, the problem persisted! This may be because I am using a low frequency to the scope which is violating the Nyquist-Shanon law.
as for SampleCLK I did not try it yet.
I am just seeking good practices to simulate the expected signal with the minimum computational price
Hi Yuri,
For discrete diagrams like yours, you should better use the SampleCLK everywhere. This guarantees you only have a single event thus you don’t have to fight against aliasing issues.
