I would like to generate a plot in Scilab/Xcos, using the SCOPE block, similar to the attached example, with two curves and a legend, and automatically display the overshoot D1, peak time t1, and 5% settling time t5% directly on the graph.
Is there a built-in Scilab/Xcos function or CPGE tool that allows this with SCOPE? If so, could you please indicate how to use it?
Thank you for your help.
