Can these font sizes be set in some way?
IMHO this is supposed to be the “Desktop font” set on the Preferences GUI. This is not working as expected !
Scilab GUI is difficult to work with on HiDPI displays (#13811) · Issues · scilab / scilab · GitLab indicates a <option value="-Dsun.java2d.uiScale=2.0"/> JVM option to enforce a scaling. Could you try it ?
Thanks David,
Doesn’t seem to help.
I did find out that I can increase it by increasing “Make Everything Bigger” setting on Windows.
So that helps, but the text seems blurry.
